Can the point cloud visibility on off be done in ilogic of inventor
Dear Autodesk support,
                      I am trying to use the ilogic of Inventor 2015 and control the visibility on off, but i am unable too.
Note:
1) first is there a root by the way i can control it through ilogic like controlling other features....?
2) if how the variables or pre configured strings (if) works..../
3) If it will work can i make it a global use in, by configuring in ribbon so i can use it in part level from assy and in assembly level too.....
Looking forward for your reply.
HermJan.Otterman
You can use this code:
the "1" is the first pointcloud. you can also use the name like this:  item("Single machine:1")
visible:
false for off
True for on
oDoc = ThisDoc.Document
Dim oPointcloud As Pointcloud = odoc.componentdefinition.pointclouds.item(1)
oPointcloud.Visible = False
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
