Can't run rule
Can't run rule
j_weber
Mentor Mentor
Can't run rule
j_weber
Hello everyone,
I don't exactly understand the process
I use iLogic to create a parameter in a drawing and then fill it with a multi-list. Before doing this, I check whether the parameter exists in the drawing.
oUserParam = ThisApplication.ActiveDocument.Parameters.UserParameters
Try
	oKatType = oUserParam.Item("Kategorie")
Catch
	oKatType = oUserParam.AddByValue("Kategorie","Bauteil", UnitsTypeEnum.kTextUnits)
	MultiValue.SetList("Kategorie", "Bauteil", "Baugruppe", "Presantition", "Zeichnung")
End Try
InventorVb.DocumentUpdate()
This works quite well so far.
Then the current value in the Category parameter is to be written to an Inventor property.
iProperties.Value("Summary", "Category") = Kategorie
I then have a second rule, which could also be included directly in the first rule.
But when I execute the second rule, nothing happens at first. But if I go into the rule editor and back out with Save and Execute, the rule works as I want.
I've created a little screencast to show the situation.
https://autode.sk/3FAlOzP
I can't find a way to write the value directly into the property and use it.
Can someone perhaps give me a tip?
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
gopinathmY575P
Hi Try this
iProperties.Value("Summary", "Category") = "Hi"
iLogicVb.UpdateWhenDone = True
j_weber
Hallo @gopinathmY575P
thanks for you replay.
I try it but nothing changes. I didn't work
Jörg Weber
mateusz_baczewski
@j_weber
Change:
On this:
Dim oKatValue As String
Try
	Dim oKatParam As UserParameter = oUserParam.Item("Kategorie")
	oKatValue = oKatParam.Value
Catch
	MsgBox("Parameter not found!")
End Try
iProperties.Value("Summary", "Category") = oKatValue
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
j_weber
Hallo @mateusz_baczewski
thank a lot
That work good.
Jörg Weber
mateusz_baczewski
@j_weber
Glad to hear that! I’d appreciate it if you marked my answer as the solution. 😃
