Can't find Workpoint first time 2017
rikard.nilsson
rikard.nilsson
I have a very strange problem with getting workpoints in a part.
If you open my attacehd assembly it will give you an error because I set my rule to run AfterOpen.
But if you then run the rule manually it will give a messagebox for every Workpoint in the part (Center Point and WPTest)
It always find the Document but fails in the row with
Document1.ComponentDefinition.WorkPoints
Why is that?
Is there any way to make the code to work after open?
Regards
Rikard
rikard.nilsson
Directly after posting I think I found the answer myself..
Document1 has to be PartDocument or AssemblyDocument then it works..
/Rikard
