Can't change column width in Custom Table
Skadborg.NTI
Message 1 of 10
Skadborg.NTI
If I place a Custom Table (General Table) on an idw, I can easily change column width in the GUI.
According to API-help Column.Width is read/write.
But if I try to set the width in iLogic I get an "unspecified error."
Dim oSheet = ActiveSheet.Sheet
Dim oCustomTable = oSheet.CustomTables.Item(1)
oCustomTable.Columns.Item(1).Width=3.0
What is wrong in above code?
Replies (9)
Message 2 of 10
dgreatice
I try your code, but no error happen.
Are you already have custom table in active sheet?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 3 of 10
Skadborg.NTI
File with table and rule attached
Message 4 of 10
dgreatice
im upgrade you code with input field.
i = InputBox("Colomn Number?", "Colomn Input")
If i = "" Then
Exit Sub
End If
DefaultWidth = (oCustomTable.Columns.Item(Val(i)).Width) * 10
j = InputBox("Width?", "Input Width", DefaultWidth)
oCustomTable.Columns.Item(Val(i)).Width = (Val(j) / 10)
Message 5 of 10
Skadborg.NTI
Exact same error. Tried both 2017 and 2018, and on three different machines.
Message 6 of 10
dgreatice
try This,
Dim oDwgDoc as DrawingDocument
oDwgDoc = Thisapplication.ActiveDocument
Dim oSheet as Sheet
oSheet = oDwgDoc.ActiveSheet
Dim oCustomTable as CustomTable
If i = "" Then
Exit Sub
End If
Message 7 of 10
Skadborg.NTI
Found the problem. It is caused by Windows Regional Settings. If I change to English(USA) it runs without problems.
Message 8 of 10
sellvakumarmech
it's working great, but I can't reduce the column width less the length of text(Column titel). when I use column width as 0.1. its returns as text length column width. could you please find a solution to this issue.
oCustomTable.Columns.Item(1).Width = .1
is there any possibility to kill the problem ASAP.
thanks in advance
Selvakumar v
Message 9 of 10
dgreatice
try with comma maybe?
Message 10 of 10
sellvakumarmech
Hey,
Thanks for your involvement in this.
Based on your idea, I add the comma to the title Text value. but it's now working. instead on that, I have used the new line command. so I believe, it reduces the width of the columns. if you have two or more word sentence as the title I suggest using the new line to reduce the column width as below.
    oTitles(0) = "BRAND" & vbCrLf & "NAME"
    oTitles(1) = "CATALOG NO."
    oTitles(2) = "PART" & vbCrLf & "DESCRIPTION"
maybe I wrong with your idea, kindly drive me in the right direction.
Looking for your solution...
Selvakumar V
