Can someone please show the correct way to write these equation in parameters?
chris
Advisor Advisor
chris
I was wondering if someone could please explain or show the correct way to write these equations (a & b) in parameters and what the unit type should be for both (a & b)?
(I've tried both tan & cos, but I'm not writing something correct, as the equation is always red text)
Lars_Greft
You need the inverse function (atan, acos, asin), unit type is deg for both values
a = atan(Rise / Run)
b = atan(Run / Rise)
chris
@Lars_Greft  !!! Thank you!!!
karthur1
