Can my rule changing part number based on BOM structure be fixed?
ssiem
ssiem
Hello
I'm using this rule and i found there is some point need to be fixed
this is my rule
Option Explicit On
Class ThisRule
	Dim As_count As Integer = 0
	Dim Pr_count As Integer = 0
	Dim Wl_count As Integer = 0
	Dim St_count As Integer = 0
	Dim Pt_count As Integer = 0
	Dim Rf_count As Integer = 0
	Sub Main
		ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
		Dim oADoc As AssemblyDocument = ThisDoc.Document
		Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
		'BOM Export 후 xml파일과 아래 경로를 일치할것
		oBOM.ImportBOMCustomization("D:\UC BOM.xml")
		oBOM.StructuredViewEnabled = True
		oBOM.StructuredViewFirstLevelOnly = False
		oBOM.SetPartNumberMergeSettings(False)
		Dim oBOMView As BOMView = oBOM.BOMViews.Item("구조적")
		oBOMView.Sort("질량", False, "체적", False)
		oBOMView.Renumber()
		oBOMView.Sort("Part Number", True)
		oBOMView.Renumber()
	End Sub
	Private Sub WritePartMumb(ByVal oBOMRows As BOMRowsEnumerator)
		For Each oRow As BOMRow In oBOMRows
			If Not IsStandardContentCenterRow(oRow) Then
				Dim partnumber As String = PartNumberGenerator(oRow)
				If partnumber <> "" Then
					oRow.ComponentDefinitions(1).Document.PropertySets(3)(2).Value = partnumber
			If oRow.ChildRows IsNot Nothing Then
				WritePartMumb(oRow.ChildRows)
		Next
	End Sub
	Private Function PartNumberGenerator(ByVal oRow As BOMRow) As String
		Select Case oRow.BOMStructure
			Case BOMStructureEnum.kNormalBOMStructure
				Dim rowDocType = GetDocumentType(oRow)
				If rowDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
					As_count = As_count + 1
					Return "As-" & As_count.ToString("000")
				ElseIf rowDocType = DocumentTypeEnum.kPartDocumentObject Then
					Pr_count = Pr_count + 1
					Return "Pr-" & Pr_count.ToString("000")
				Else
					Return ""
			Case BOMStructureEnum.kInseparableBOMStructure
				Wl_count = Wl_count + 1
				Return "Wl-" & Wl_count.ToString("000")
			Case BOMStructureEnum.kPurchasedBOMStructure
				St_count = St_count + 1
				Return "St-" & St_count.ToString("000")
			Case BOMStructureEnum.kPhantomBOMStructure
				Pt_count = Pt_count + 1
				Return "Pt-" & Pt_count.ToString("000")
			Case BOMStructureEnum.kReferenceBOMStructure
				Rf_count = Rf_count + 1
				Return "Rf-" & Rf_count.ToString("000")
		End Select
		Return "" ' default case if we can't get a part number
	End Function
	Private Function IsStandardContentCenterRow(ByVal oRow As BOMRow) As Boolean
		For Each compDef As ComponentDefinition In oRow.ComponentDefinitions
			Dim partCompDef As PartComponentDefinition = TryCast(compDef, PartComponentDefinition)
			If partCompDef IsNot Nothing AndAlso partCompDef.IsContentMember Then
				Return True
		Next
		Return False
	End Function
	Private Function GetDocumentType(ByVal oRow As BOMRow) As DocumentTypeEnum
			If partCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kPartDocumentObject
			Dim assemCompDef As AssemblyComponentDefinition = TryCast(compDef, AssemblyComponentDefinition)
			If assemCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kAssemblyDocumentObject
		Next
		Return DocumentTypeEnum.kUnknownDocumentObject
	End Function
End Class
other function work well but it's not working  if it is Phantom or Reference structure like this
Could you help me please?
A.Acheson
Hi @ssiem
You can use index 1 to get to model tab so you can affect the Bom Structure before it is filtered into the Structured Bom View.
 Dim oModelBOMView As BOMView = oBOM.BOMViews.Item(1)
Regards
Alan
ssiem
Sorry you mean like this?
Option Explicit On
Class ThisRule
	Sub Main
		oBOM.ImportBOMCustomization("D:\STCRECH.xml")
		oBOMView.Renumber()
		oBOMView.Renumber()
	End Sub
		Next
	End Sub
				Else
					Return ""
		End Select
	End Function
				Return True
		Next
		Return False
	End Function
		Next
	End Function
End Class
A.Acheson
Yes but you also need to pass in the bomview to the sub routine argument.
Regards
Alan
ssiem
WoW it works thank you so much!
Option Explicit On
Class ThisRule
	Sub Main
		oBOMView.Renumber()
		oBOMView.Renumber()
	End Sub
		Next
	End Sub
				Else
					Return ""
		End Select
	End Function
				Return True
		Next
		Return False
	End Function
		Next
	End Function
End Class
ssiem
oh i think it invalidate independent sequence by BOM structure
it give number as partnumber together
* no it seems not to give number together it think some number is ignored
for example pt-001 pt-002 are missing
and same symtom with other like St, Wl
