Message 1 of 1
After Open Document Event Trigger when using Open drawing from Vault
Looking for some clarification around event trigger behavior please. We have an iLogic routine that is set to run as the event trigger "After Open Document" on drawings. This work fine in most cases except when the user right clicks in the model and uses the "Open Drawing From Vault" command. In this scenario the trigger does not fire and the iLogic routine is not run. Have tested this on the same drawing and it works fine if opening from directory, using open in Inventor or even right clicking in model and selecting "Open Drawing" it is only the open from vault that does not work. Is this the expected behavior? If so is there any way around it?
