Can I use iLogic to write a description similar to how the "<>" works in the iproperties "description"?
chris
Advisor Advisor
Message 1 of 9
chris
I am wondering how to create a description from parameters and regular text similar to how you are able to create descriptions in the iProperties "Description" slot.
Description example: =<TUBING, SQUARE <Width> X <Height> X <Length> LONG
how would I write this same type of "description" in iLogic using the parameters (Width, Height, Length) and the plain text of TUBING, SQUARE & Long)
Replies (8)
Message 2 of 9
tyler.warner
How about something like this. The underscores are to break the text into multiple lines.
iProperties.Value("Project", "Description") = "<TUBING, SQUARE <" _
& Parameter("Width") _
& "> X <" & Parameter("Height") _
& "> X <" & Parameter("Length") _
& "> LONG"
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 3 of 9
Curtis_Waguespack
Hi @chris
I don't think you can insert the Parameters to be a "live" formula in this way, instead you must use iproperties.
Meaning that if you use Parameters it will simply get the value of the parameter at the moment, and will not update the description if the parameter changes in the future ( unless the rule runs).
What you can do though is export the parameter as an iProperty:
Then you can use something like this to set the formula in the description:
iProperties.Value("Project", "Description") = _
"= TUBING, SQUARE <Width> X <Height> X <Length> LONG"
This will give you a result such as this:
Recall that you can format the way the parameter export by right clicking them as shown:
And then using these options:
I hope this helps.
Curtis
Message 4 of 9
chris
@Curtis_Waguespack Yes, this is how I have always done this, except last night it wasn't working.
see video
Message 5 of 9
chris
what I want to do with the square / Rect tubing is to have the parameter "Shape" be available in the description... but it's not working
Message 6 of 9
A.Acheson
If the parameter is a text parameter this won't work directly because of the lack of export option to iproperty.
You need the ilogic rule first to create a custom iproperty and set it to the parameter value.
iProperties.Value("Custom", "Shape") = Shape
What is being used in the forumula is not the parameter but rather the iproperty name either.
Regards
Alan
Message 7 of 9
chris
@A.Acheson @Curtis_Waguespack @tyler.warner
Tyler, I've never seen the "case" word in iLogic, what is that?
Message 8 of 9
A.Acheson
Here is how to remove unit identifier for inches [ " ]  from a string. Use the string function replace.
1. Populate Description by code
'Trigering Criteria, Local Parameters are only used to trigger the rule to run.
a = Width
b = Height
c = Thk
'Replaces " with Empty String.
Dim width As String = iProperties.Value("Custom", "Width").ToString.Replace("""", "")
Dim height As String = iProperties.Value("Custom", "Height").ToString.Replace("""", "")
Dim thk As String = iProperties.Value("Custom", "Thk").ToString.Replace("""", "")
'Set Description iproperty.
iProperties.Value("Project", "Description") = "L " & width & " x " & height & " x " & thk & " x "
 Result:
2. Populate Description by expression:
= L <Width> X <Height> X <Thk>
a = Width
b = Height
c = Thk
iProperties.Value("Custom", "Width") = iProperties.Value("Custom", "Width").ToString.Replace("""", "")
iProperties.Value("Custom", "Height") = iProperties.Value("Custom", "Height").ToString.Replace("""", "")
iProperties.Value("Custom", "Thk") = iProperties.Value("Custom", "Thk").ToString.Replace("""", "")
Triggering this rule was a lot trickier than I had imagined.
What did Work:
It is necessary to have the local parameters in the rule in order for the rule to be automatically triggered on parameter change.
What didn't work:
  • Simply setting the rule to run on the event trigger of change of iproperties did not work. Changing the parameter and exporting the parameter is not considered a change to iproperty it seems.
Regards
Alan
Message 9 of 9
chris
FYI, I got it figured out !!!!!
