Can i change all of Partnumber automatically with this rule?
ssiem12
Message 1 of 9
ssiem12
Hello
my rule is this
Basic structure is '00-000'
it start from Assemblydocument
Following BOM in inventor
Rule for prefix
Normal - two type (As for assembly, Pr for part)
Inseparable - Wl
Purchased - St
Phantom - Pt
Reference - Rf
(Standard product is exception,No changing Part number)
Rule for suffix
001
002
003
004...
this sequence is ascending order of mass
as a exception if it has same mass by missing selecting material or something, ascending order of volume is okay
it should be different according to the prefix
for example Part number
As-001 (assembly and first heavy one)
As-002(assembly and second heavy one)
Pr-001(Part and first heavy one)
Pr-002(Part and second heavy one)
Wl-001(Welding and first heavy one)
I hope you give me your Wisdom
Replies (8)
Message 2 of 9
dalton98
Heres something i came up with. You will first need to export a BOM template with a row  for 'Mass' and volume
Class ThisRule
	Dim As_count As Integer = 0
	Dim Pr_count As Integer = 0
	Dim Wl_count As Integer = 0
	Dim St_count As Integer = 0
	Dim Pt_count As Integer = 0
	Dim Rf_count As Integer = 0
	Sub Main
		ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
		Dim oADoc As AssemblyDocument = ThisDoc.Document
		Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
		'create a bom with a column for Mass then export it
		oBOM.ImportBOMCustomization("Z:\BOM_Style.xml")
		oBOM.StructuredViewEnabled = True
		oBOM.StructuredViewFirstLevelOnly = True
		Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
		oBOMView.Sort("Mass", False, "Volume", False)
		oBOMView.Renumber()
		For Each oRow As BOMRow In oBOMView.BOMRows
			Dim partnumber As String = PartNumberGenerator(oRow)
			oRow.ComponentDefinitions(1).Document.PropertySets(3)("Part Number").Value = partnumber
		Next
		oBOMView.Sort("Part Number", True)
		oBOMView.Renumber()
	End Sub
	Function PartNumberGenerator(oRow As BOMRow)
		Select Case oRow.BOMStructure
			Case BOMStructureEnum.kNormalBOMStructure
				If oRow.ReferencedFileDescriptor.ReferencedFileType = kAssemblyFileType
					As_count = As_Count + 1
					Return "As-" & As_count.ToString("000")
				Else
					Pr_count = Pr_count + 1
					Return "Pr-" & Pr_count.ToString("000")
				End If
			Case BOMStructureEnum.kInseparableBOMStructure
				Wl_count = Wl_count + 1
				Return "Wl-" & Wl_count.ToString("000")
			Case BOMStructureEnum.kPurchasedBOMStructure
				St_count = St_count + 1
				Return "St-" & St_count.ToString("000")
			Case BOMStructureEnum.kPhantomBOMStructure
				Pt_count = Pt_count + 1
				Return "Pt-" & Pt_count.ToString("000")
			Case BOMStructureEnum.kReferenceBOMStructure
				Rf_count = Rf_count + 1
				Return "Rf-" & Rf_count.ToString("000")
		End Select
	End Function
End Class
Message 3 of 9
ssiem12
Thank you for your kindness
and i have a question  you mention exporting BOM first
is it mean this?
and i should put excel file on proper place right?
like "Z:" you put on code
and change file name right?
Message 4 of 9
dalton98
This one. It saves a custom BOM template for columns, spacing, etc. You will probably have to change the property names from english aswell.
Message 5 of 9
ssiem12
Thank you and could you please help me one more?
I success by 30row
and there is error like below
so i check 30 row and what i found is kAssemblyFileType is not defined i guess
because when i put cursor on this function speech bubble doesn't pops out but other function do
could it be right?
Message 6 of 9
dalton98
Try changing these 3 values. You will probably need to change the text "Part Number" too
Class ThisRule
	Sub Main
		oBOM.SetPartNumberMergeSettings(False)
		oBOMView.Renumber()
			oRow.ComponentDefinitions(1).Document.PropertySets(3)(2).Value = partnumber
		Next
		oBOMView.Renumber()
	End Sub
				If oRow.ReferencedFileDescriptor.ReferencedFileType = 56323
					As_count = As_count + 1
				Else
				End If
		End Select
	End Function
End Class
Message 7 of 9
ssiem12
hello i finally ran this rule thank you
and it's modified rule
Option Explicit On
Class ThisRule
	Sub Main
		'BOM Export 후 xml파일과 아래 경로를 일치할것
		oBOM.ImportBOMCustomization("D:\test.xml")
		Dim oBOMView As BOMView = oBOM.BOMViews.Item("구조적")
		oBOMView.Sort("질량", False, "체적", False)
		oBOMView.Renumber()
			If Not IsStandardContentCenterRow(oRow) Then
				If partnumber <> "" Then
				End If
			End If
		Next
		oBOMView.Renumber()
	End Sub
	Function PartNumberGenerator(oRow As BOMRow) As String
				Dim rowDocType = GetDocumentType(oRow)
				If rowDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
				ElseIf rowDocType = DocumentTypeEnum.kPartDocumentObject Then
				Else
					Return ""
				End If
		End Select
		Return "" ' default case if we can't get a part number
	End Function
	Function IsStandardContentCenterRow(oRow As BOMRow) As Boolean
		For Each compDef As ComponentDefinition In oRow.ComponentDefinitions
			Dim partCompDef As PartComponentDefinition = TryCast(compDef, PartComponentDefinition)
			If partCompDef IsNot Nothing AndAlso partCompDef.IsContentMember Then
				Return True
			End If
		Next
		Return False
	End Function
	Function GetDocumentType(oRow As BOMRow) As DocumentTypeEnum
			If partCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kPartDocumentObject
			End If
			Dim assemCompDef As AssemblyComponentDefinition = TryCast(compDef, AssemblyComponentDefinition)
			If assemCompDef IsNot Nothing Then
				Return DocumentTypeEnum.kAssemblyDocumentObject
			End If
		Next
		Return DocumentTypeEnum.kUnknownDocumentObject
	End Function
End Class
one thing i'd like to ask is can i change Partnumber every class not first class in BOM
Message 8 of 9
dalton98
Do you mean running this rule from a top level assembly and changing the part numbers in the sub level assemblies? If so, this would be harder and require a lot more testing.  It would involve using a recursive sub routine ex.
oBOM.StructuredViewFirstLevelOnly = False
Sub RecursiveBOM(oRows As BOMRowsEnumerator)
For Each oRow As BOMRow in oRows
If oRow.ChildRows.Count > 1
RecursiveBOM(oRow)
End If
Next
End Sub
If you mean the class in the code, You do this so you don't have to redefine the part number count every sub. If you are wanting to do this for every assembly in your main assembly file you will have to do this. By adding ByRef ex.
Function PartNumberGenerator(ByRef As_count as Integer, ByRef Pr_count as Integer, oRow As BOMRow) As String
Message 9 of 9
ssiem12
What i want is first one you mention and recursive function uhmm
i got C- in C++ class cuz of this
