Call "Place iLogic Component" from VBA
Hi, Experts
The iLogic command called "Place iLogic Component" works very fine for me, but I need to put this command in a toolbar button that insert a specific part. Is there a way to do this?.
I know how to do this using the inventor "place component" command using VBA, but, I don't know if that command can be called from a VBA function.
Thanks for your help!.
MjDeck
You can start the Place iLogic Component command using this code:
Dim controlDef as ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.PlaceComponent")
controlDef.Execute
Mike Deck
Software Developer
Autodesk, Inc.
Hi, MjDeck
Thank you very much for your time, excellent answer!!
This works great.  Now is there a way to specify a specific iLogic part with out the dialog box opening up?  I just want to place a series of buttons that the user pushes on a form and it opens up that iLogic Part.
Hi!
I am stuck at this command called "Place iLogic Component". I cannot find it anywhere, can you please write the code down?
Thank you very much in advance!
cencinaNB2ET
The command just simulates pressing the button.
How do we fill up the file browser with code?
