C# Program for sketch and extrude a square with a hole
chsgmanohar
chsgmanohar
1)I am a beginner with automation. I would like to learn step by step. so kindly help me out to learn.
2)Is there any specific course to complete inventor automation.
Thanks in advance
FINET_Laurent
Hi @chsgmanohar
A good starting point would be to read the documentation in the Inventor application, accessible on the help button :
There is pretty much anything you need there, with explanations to samples programs to illustrate topics.. As an exemple you can type "API" :
This explais basics things you need to know.. Then from there you can get on searching specific this..
This forum is also a good source of information.
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
