C++ AddIn, Server, Deactivate or OnDeactivate
oransen
oransen
The plugin examples shows the body to
STDMETHODIMP CSimpleAddInServer::Deactivate(void)
(for example). But the new wizard creates a function like this:
STDMETHODIMP CCh1AddInAddInServer::OnDeactivate ()
Do they serve the same purpose? And so should I only use OnDeactivate?
xiaodong_liang
Autodesk Support
Autodesk Support
As I remember, this is just because which type of interface is selected when creating the addin (see attached fig).
if Use IDispatch interfac,  it is OnDeactivate (). otherwise, Deactivate. the similar to activate method.
oransen
Yes, one was from an old plugin example and one from a wizard generated project.
