Thanks for the solved items code, its works perfectly.
But my case after open the folder, i need to select only drawings files (*.idw) and then i add my other requirement rules, like >> For Example: all open drawings i delete particular sketched symbol..... like other performance.
So i need open folder and select drawings files.
Thanks.
Below is solved code as per your link
Imports System.Windows.Forms
Dim filepath As String = "K:\" Dim selectedfolder As String Dim oFolderDlg As New FolderBrowserDialog oFolderDlg.SelectedPath = filepath Dim oResult As DialogResult = oFolderDlg.ShowDialog() If oResult = DialogResult.OK selectedfolder = oFolderDlg.SelectedPath End If Try Process.Start(selectedfolder) Catch End Try
If you want to select files then use the inventor dialogue in the help files here. Change the extension to filter for drawings. You will likely find a version on this forum allready modified for multiple file selection also. Or just poke around with the options in this one and learn little.
' Create a new FileDialog object.
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
' Define the filter to select part and assembly files or any file.
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
' Define the part and assembly files filter to be the default filter.
oFileDlg.FilterIndex = 1
' Set the title for the dialog.
oFileDlg.DialogTitle = "Open File Test"
' Set the initial directory that will be displayed in the dialog.
oFileDlg.InitialDirectory = "C:\Temp"
' Set the flag so an error will be raised if the user clicks the Cancel button.
oFileDlg.CancelError = True
' Show the open dialog. The same procedure is also used for the Save dialog.
' The commented code can be used for the Save dialog.
On Error Resume Next
oFileDlg.ShowOpen
' oFileDlg.ShowSave
' If an error was raised, the user clicked cancel, otherwise display the filename.
If Err Then
MsgBox "User cancelled out of dialog"
ElseIf oFileDlg.FileName <> "" Then
MsgBox "File " & oFileDlg.FileName & " was selected."
End If
Above code works fine and open the folder, but i am not able to select multiple files (drawings) and also not able to open the drawings.
If i click open button, its not works.
That sample shown earlier is the generic sample so you need to customize to what you need. See image below, once the object is declared you can see all the methods available.
One specific for drawings.
'present a File Selection dialog
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.MultiSelectEnabled = True
oFileDlg.ShowQuickLaunch = True
' Define the filter to select files
oFileDlg.Filter = "Inventor Drawing Files (*.idw;*.dwg)|*.idw;*.dwg"
oFileDlg.DialogTitle = "Choose the files to work with."
'oFileDlg.ShowSave()
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
selectedfiles = oFileDlg.FileName
End If
' Split the string on the vertical bar character.
Dim sFiles As String() = selectedfiles.Split(New Char() {"|"c})
'Loop through result strings with For Each.
For Each sFile As String In sFiles
Logger.Info("Drawing File.", sFile)
Next
Now multiple drawings files selected thanks, but not able to open the drawings in inventor. If i select the multiple drawings and click open no operation carried.
The purpose of the dialogue is to return file paths not to open the files. Your recreating the User Interface by code so you need to open the files by code also. The line below needs to be inserted in the for loop. Did the logger statement show you the correct file paths?
ThisApplication.Documents.Open(filepath,True)
Also now i add delete sketched symbol in end of the browser folder path code.
how can i add and merge the code. can you help
My requirements:
1. Open browser folder as working space.
2. Select the drawings files as per the requirements and selected file to be open.
3. Then targeted sketched symbol delete my open drawings.
4. Save and close
'present a File Selection dialog Dim oFileDlg As Inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = True oFileDlg.ShowQuickLaunch = True ' Define the filter to select files oFileDlg.Filter = "Inventor Drawing Files (*.idw;*.dwg)|*.idw;*.dwg" ' Set the title for the dialog. oFileDlg.DialogTitle = "Choose the files to work with." On Error Resume Next 'oFileDlg.ShowSave() oFileDlg.ShowOpen() If Err.Number <> 0 Then Return ElseIf oFileDlg.FileName <> "" Then selectedfiles = oFileDlg.FileName End If ' Specify the name of the sketched symbol you want to delete targetSymbolName = "Reference document No" ' Loop through all drawing files in the folder While drawingFile <> "" ' Open each drawing document Dim oDoc As DrawingDocument oDoc = ThisApplication.Documents.Open(folderPath & drawingFile, True) ' Check if the document is a drawing If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then ' Loop through all sheets in the drawing For Each oSymbol In oDoc.ActiveSheet.SketchedSymbols 'look for the symbol by name If oSymbol.Name = "Reference document No" Then oSymbol.Delete End If Next oDoc.Save() oDoc.Close() End If ' Get the next drawing file in the folder drawingFile = Dir End While MsgBox("Deletion of specific sketched symbols completed for all drawings in the folder.", MsgBoxStyle.Information, "Complete")
The code you worked in over here in this other post is more complete than the one supplied in this post so please work with the other post rather than duplicate.
