Broswer Nodes
Broswer Nodes
dbrblg
Broswer Nodes
dbrblg
Is it possible to determine which nodes are expanded using the API?
I want to make some changes to the node information in an assembly browser but as there are many hundred parts so I only want to do the operation on the expanded nodes to keep any delay to a minimum.
There are also useful implications to part browser nodes where this could be useful too......
Is this possible?
There is a property in the API for BrowserNode called "Expanded" which returns True or False.
Here is a simple (iLogic) example of how you could use it :
Dim oBrowserNode As BrowserNode
Dim oTopNode As BrowserNode
oTopNode = ThisApplication.ActiveDocument.BrowserPanes.ActivePane.TopNode
For Each oBrowserNode In oTopNode.BrowserNodes
If oBrowserNode.Expanded = True Then
'do your code for the expanded nodes here
Next
Hope it helps
Tom
dbrblg
oh Smiley Frustrated, I wasn't aware this existed.
I did have a quick look throught he help files....
Ah well, looks like it might well do what i'm after.  Thanks for this Smiley Happy
