BOM Quantity Based On Number of Assemblies
This might be something that's been covered before, but it's Friday, my brain took a vacation day and i can't seem to find the answer anywhere else.
When you open the BOM (or Parts List) for an Assembly, it will show you all of the quantities for each part that is required to build one Assembly. I need to find a way to make the BOM show these quantities based on the number of assemblies required. The number of assemblies is entered as a custom iProperty and will vary every time the model is used.
I know that i can use ThisBOM.OverrideQuantity in iLogic, but the assembly I'm working with is flexible and contains patterns. So i can't use the code to set static quantities because the quantities vary based on the patterns and some parts might not be part of the assembly when it's finished.
Manually updating the quantities in the BOM is NOT an option either.
Any thoughts??
Just a thought, but starting from the assembly iterate through all the referenced documents to get the total number of occurances, then get the number of assemblies from your custom iProperty and multiply by the number of occurances
To illustrate -
Dim oAssDoc As AssemblyDocument
Set oAssDoc = ThisApplication.ActiveDocument
Dim oDocs As DocumentsEnumerator
Set oDocs = oAssDoc.AllReferencedDocuments
Dim oDoc As Document
Dim oOccs As ComponentOccurrencesEnumerator
Set oOccs = oAssDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc)
oNoOfParts = oOccs.count * oCustomPropSet.Item("NoOfAssemblies").Value
Does any assembly have all the occurrances you need to count?  I am getting ready to release a addin that allows you to select a drawing view, and then any assembly and it creates a partslist with the qty from the selected assembly that are in that view.
I have asked that question for 2 years at every AutoDesk convention in Las Vegas and have yet to find an answer, even tho i am always told how simple it should be, so when someone figures it out please let me know.
Why not create new assembly with component pattern of the YourQTY of your assembly and use its BOM?
This is what I found works for my particular needs. Since my assembly will always have the same static parts in it (5 parts total), I can set a parameter for each part that is equal to the bom qty *  the # of assemblies. Then I can override the bom qty with that parameter. See below...
A_Count <-- # of Parts * # of Assemblies
A_Part <-- Part Name
Asm_Qty <-- # of Assemblies
A_Count = ThisBOM.CalculateQuantity("Model Data", "A_Part") * Asm_Qty
ThisBOM.OverrideQuantity("Model Data", "A_Part", A_Count)
(This code is executed in the assembly)
