BOM export error
BOM export error
BOM export error
Hello!
I'm trying to export BOM from Inventor iassembly to xls format. I do it with iLogic rule:
ThisBOM.Export("Structured", "C:\TEST.xls", kMicrosoftExcelFormat)
Before it, if I look at the Inventor's interface, I see the correct number:
But in Excel for all members I see number "3":
And if I look Inventor's interface again (after import), I see all numbers is "3" too:
How can I fix it? The error appears in Iventor 2014 and 2015.
Vladimir.Ananyev
I have logged Change Request 105248 "Incorrect iAssembly BOM after BOM export to Excel file" in our database.
Please make a note of this number for future reference. You are welcome to request an update on the status of this issue, or to provide us with additional information.
Thank you very much for this case!
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
GPJHKeiren
I have the same issue with Inventor Pro 2012 and would be very happy, when there is a solution available soon!
GPJHKeiren
Finally solved in Inventor 2016 with 2016.2.4 Hotfix
