Bolted Connection Upgrade via Ilogic
I hope you'll forgive my English, as I'm using the translator to translate into English.
It turns out I was modifying a structure using ilogic, which has some bolts assembled using a point (hole + bolt).
But it turns out that when I tried to modify the distances of the structure, the bolt connections didn't update.
I searched the internet for information and found some code, but it didn't update the bolt connections. It may be due to the inventor's version. I'm currently using version 2025.
The information I found that didn't work for me is the following:
https://clintbrown.co.uk/2019/02/10/ilogicbolts/
