Bolted Connection Upgrade via Ilogic
claudio_cerdaD3C96
Observer Observer
claudio_cerdaD3C96
Observer
Observer
I hope you'll forgive my English, as I'm using the translator to translate into English.
It turns out I was modifying a structure using ilogic, which has some bolts assembled using a point (hole + bolt).
But it turns out that when I tried to modify the distances of the structure, the bolt connections didn't update.
I searched the internet for information and found some code, but it didn't update the bolt connections. It may be due to the inventor's version. I'm currently using version 2025.
The information I found that didn't work for me is the following:
https://clintbrown.co.uk/2019/02/10/ilogicbolts/
CCarreiras
Hi!
I believe that the bolt connection tool is not available to use iLogic, so, There's no code/functions to control this tool.
What i do instead of using bolt connection in parametric systems is,  substitute the bolts and nuts with code based in the geometry changes.
CCarreiras
