Bolted Connection "Design Accelerator".
is there a way to Replace the "bolt" Component Occurrence with api?
Vladimir.Ananyev
See here please
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Accessing-Bolted-Connections-through-i...
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
thank you for the information, i was able to do what i wanted with the API using oPart.PutLogicalFileNameUsingFull(sFullFileName). but once again thank you for replying and the information.
