Blocked paramets - form
patryk_walkusz
patryk_walkusz
Hi
Can I block writing paramets and unlock in forms?
I need add option to lock or unlock all this paramets on top. When someone want edit this then they will unlock. It will be good, to dont change somethink for mistake.
mat_hijs
You can add another userparameter, for example "Unlock_Parameters". You can add this to your form like any other parameter. Then, for all parameters, properties, ... you want to lock/unlock you set the enabling parameter to "Unlock_Parameters". You can also set an enabling parameter for a group, that way you can lock/unlock multiple parameters without having to set all their enabling parameters separately.
patryk_walkusz
Thank you, it work like i wanted!
