Bevel Gear vba
Bevel Gear vba
panagiotishp18
Bevel Gear vba
panagiotishp18
hello i am trying to create an automation to create bevel gears i already did the back cone but i have problems creating the involute profile of the teeth. Any ideas on how to create the toothspace profile and the cut it.
Michael.Navara
EDIT: Sorry off topic
I don't test your code, but the first thing is you need to create closed loop for profile. See this topic it can help you to create closed loop. Method CreateClosedPolyLine works in any 2D sketch (not only in drawing).
Michael.Navara
Why you don't use built-in functionality?
panagiotishp18
Hello the project is to create it again using vba code thats why i dont use the built in addin
Michael.Navara
You can see the result of built-in functionality for a reference. Try to reuse modeling concept and implement your own. But it will require a lot of time.
You can try to create a template for the gear and just modify its parameters. It can be easier then create the model from scratch by code.
