Best way to detect if part is flat
Message 1 of 9
I need to check if a sheet metal is flat or if it hase some bends..
I was thinking to compare the thickness with Z-value of it s bounding box.. if it is the same then it is flat..
is there a better way?
If this is the best way, how can i retrieve the thickness in code?
thank you!
Replies (8)
Message 2 of 9
basnederveen
I am looking for the same thing, I was worried about using the rangebox when the plate is not in one of the (XY,YZ etc) workplanes.
Message 3 of 9
me too, but on the otherhand i run my code on the IPT file, and on that file the thickness is always aligned to one of the axes.. (at least should be if you dont make a mess while drawing.. 😄 )
Message 4 of 9
basnederveen
We use skeleton parts so it is not guaranteed that the part is parallel to one of the planes... And if I'm correct the 'rangebox' is parallel to the coordinate system
Message 5 of 9
well, that makes ONE good exception.. 😄 but does not apply to my case...
Message 6 of 9
AlexFielder
In your case @basnederveen I guess you could prompt the user to select the longest, flattest face (for those parts which aren't parallel to the major axes) and work from that?
I guess it depends on whether you would want the rule to function manually or not.
Message 7 of 9
marcin_otręba
Dim doc As PartDocument
Set doc = ThisApplication.ActiveDocument
Dim oFlatPattern As FlatPattern
Dim ocompdefs As SheetMetalComponentDefinition
Set ocompdefs  = doc.Componentdefinition
Set oFlatPattern = ocompdefs.FlatPattern
if oFlatPattern.FlatBendResults.Count>0 then
Msgbox "Part is not flat"
endif
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 8 of 9
thank you,. will this work also for files that do not have bends but maybe use contoure?
Message 9 of 9
marcin_otręba
yes, for all kinds of sheetmetal...
in case if you don't have flat pattern in part...:
   If ocompdefs.HasFlatPattern = False Then
              ocompdefs.Unfold
     oFlatPattern.ExitEdit
endif
