Bend line position [iLogic]
Owner2229
Advisor Advisor
Owner2229
Hi, I've been working on this code for a while and I'm kinda hopeless in finding solution for the last part. So here is what my code does:
1) Takes textbox from sketch on flat pattern. (The textbox is placed there by another rule.)
2) Writes the same text from textbox but using simple lines
     Subs are runed in this order (Main > WriteText > WriteSymbol > Symbol code)
--- now the part that isn't working ---
3) Takes positon of bend lines
--- end of the not working code ---
4) Places text next to each bend line ("U" for lines bend up and "D" for lines bend down)
     Subs are runed in this order (Main > BendLineText > WriteText > WriteSymbol > Symbol code)
...Then another rule exports the flat pattern with this sketch to DXF, so it can be used by our laser.
The problem is that im getting wrong positions of these bend lines. I'll be glad for any suggestions. Here are my last 3 attempts which failed, the rest of the code is in attachment.
Sub BendLineText3(oDoc As Document, oSketch As PlanarSketch, oFlatPattern As FlatPattern, oFSS As Double)
	oRotation = 0
	oFSS = oFSS * 0.5
	BendResults = oFlatPattern.FlatBendResults
	a = BendResults.Item(1).Edge.StopVertex.Point.X
	b = BendResults.Item(1).Edge.StopVertex.Point.Y
	oTextB = "U-D"
	Call WriteText(oTextB, a, b, oFSS)
End Sub
Sub BendLineText2(oDoc As Document, oSketchA As PlanarSketch, oFlatPattern As FlatPattern, oFSS As Double)
	X = BendResults.Item(1).Edge.StopVertex.Point.X
	Y = BendResults.Item(1).Edge.StopVertex.Point.Y
	oSketchA.TextBoxes.AddFitted(ThisApplication.TransientGeometry.CreatePoint2d(X, Y), "Autodesk")
End Sub
Sub BendLineText(oDoc As Document, oSketch As PlanarSketch, oFlatPattern As FlatPattern, oFSS As Double)
	oRotation = 0
	oFSS = oFSS * 0.5
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Find area")
	Try
		Ymin = 1000000
		Ymax = -1000000
		For Each oEntity in oSketch.SketchEntities
			EntityMin = oEntity.RangeBox.minPoint.Y
			EntityMax = oEntity.RangeBox.maxPoint.Y
			Ymin = Min(Ymin, EntityMin)
			Ymax = Max(Ymax, EntityMax)
		Next
		Dim oTempEdge As Edge
		Dim oTopFaceBendEdges As Edges = oFlatPattern.Edges
		Xmin = 1000000
		For Each oTempEdge In oTopFaceBendEdges
			Val1 = oTempEdge.StartVertex.Point.X
			Val3 = oTempEdge.StopVertex.Point.X
			EdgeX = Min(Val1, Val3)
			Xmin = Min(Xmin, EdgeX)
		Next
		Dim oTopFaceBendUpEdges As Edges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
		For Each oTempEdge In oTopFaceBendUpEdges
			AA = GetYValue(Val1, Val3)
			a = AA + (0.11 * oFSS)
			Val1 = oTempEdge.StartVertex.Point.Y
			Val3 = oTempEdge.StopVertex.Point.Y
			If Abs(Ymax) > Abs(Ymin) Then
				BB = GetYValue(Val1, Val3)
				a = a + (0.25 * oFSS)
				'a = a + (SheetMetal.FlatExtentsLength * 0.0016) + (0.25 * oFSS)
			Else
				BB = 0
			b = BB - (0.11 * oFSS)
			oTextB = "N"
		Next
		Dim oTopFaceBendDownEdges As Edges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
		For Each oTempEdge In oTopFaceBendDownEdges
			AA = Min(Val1, Val3)
			If AA = Xmin Then
				a = Max(Val1, Val3)
			Else
				a = Xmin + Max(Val1, Val3)
			MsgBox(Val1 & vblf & Val3 & vblf & a)
			Else
				BB = 0
			oTextB = "D"
		Next
		oTransaction.End
	Catch
		oTransaction.Abort
	End Try
End Sub
And ofc. sorry for my English.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Owner2229
NVM, this solves it:
	oRotation = 0
	oFSS = oFSS * 0.5
	Dim oLines1 As SketchLine
		oLines1 = oSketch.AddByProjectingEntity(oTempEdge)
		Val1 = oLines1.Geometry.StartPoint.Y
		Val3 = oLines1.Geometry.EndPoint.Y
		BB = Max(Val1, Val3)
		If BB = Val1 Then
			AA = oLines1.Geometry.StartPoint.X
		Else
			AA = oLines1.Geometry.EndPoint.X
		oTextB = "N"
	Next
		If BB = Val1 Then
		Else
		oTextB = "D"
	Next
End Sub
Mike
