Before save ilogic. trigger after file location
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to get a code that change an properties using before save.
but the problem is that what I can think of that I can use as trigger are part number or save location. but even though I select both is kind of selected before the ilogic code seens to run .. I can´t see this informationi before I save the second time. is there a way to get the location that is will save the file in or the part number to use in before save ?
we are using numbering scchemens in vault to give the file it number filename always = part number
