batch renaming part files in assembly
Message 1 of 1
I'm looking for the best way to rename all parts in an assembly. preferably using iLogic. Until now I've been using a code I found that renames all solids in a multi body file. In a ascending order. Afterwards I send the solids to an assembly. To do the final work. sometimes I have to go back and do a split.. Or other altercations. that messes up the order of the solids. So this is not viable solution. So I am looking for a way to do the same rename in a assembly. any suggestions. I'm quite new to ilogich.
Thanks in advance
Replies (0)
