Assembly level work feature visibility
I'm trying to get a rule working for setting the assembly level work feature visibility states on/off, this is not the same as the "Object Visibility" function in the view tab that I'm looking for, which just overrides any visibility states set in the browser.
I have a rule that sets the visibility states at part level, which works great, but if I set visibility for a work plane for instance in the top level assembly, the part level rule will not affect it, so as far as I can tell the assembly level visibility setting overrules the part level one (this is due to view rep?). I'm trying to modify the part level rule, and this is what I have so far;
SyntaxEditor Code Snippet
'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'Set as False to hide
wfBoolean = False
'set workplane dimensions visibility
For Each oWorkPlane In oAssyDoc.ComponentDefinition.WorkPlanes
oWorkPlane.Visible = wfBoolean
Next
'update the files
InventorVb.DocumentUpdate()
This code however, does not do anything as far as I can tell, how do I make this work on the assembly level to hide/show work features?
I found some code and altered it to try to make it do what I want, and this is it:
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Define the open document (top level assembly)
Dim openDoc As Document
openDoc = ThisDoc.Document
'define view rep
Dim oViewRep As DesignViewRepresentation
Dim sVRep As String
'change to something else if Default is used for something already
sVRep = "iLogicRep"
'create or activate view rep in the top level assembly
Try
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
'create new View Rep
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
   'toggle work features in the open document (top level assembly)
    For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes
    oWorkPlane.Visible = False
    Next
iLogicVb.UpdateWhenDone = True
This works like I'm wanting it to, but it only changes the state of the origin planes and work planes that are on root level in the assembly. The rule does not target work planes that belong to components and have been set to visible on the assembly level. I want all the work planes found in the assembly browser tree to be switched by the rule.
