Batch print and sort all part drawings
skyleWX4C5
Message 1 of 11
skyleWX4C5
Hello all,
I'm having an issue trying to get a working version of a code I came across here on the forums. My coding experience is very limited, but what I'm looking for: put all .dwgs for all .ipts  into an array, display the missing parts before continuing, sort the array by file name or part number, then finally, print all the .dwgs. Currently, the missing parts portion works fine, but I can't get it over the finish line.
Here is my latest attempt to fit snippets I found here:
Sub Main
'---CHECK THAT THE ACTIVE DOCUMENT IS AN ASSEMBLY---
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'---CREATE LIST OF DWGs & MISSING DWGs---
Dim dwgList As New ArrayList
Dim MissingList As New ArrayList
Dim oAsm As AssemblyDocument = ThisDoc.Document
numFiles = 0
	For Each oRefDoc As Document In oAsm.AllReferencedDocuments
        dwgPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) -3) & "dwg"
		dwgName = oRefDoc.DisplayName
If (System.IO.File.Exists(dwgPathName)) Then
				numFiles = numFiles + 1
				dwgList.Add(dwgPathName)
			Else
				MissingList.Add(dwgName)
Next
dwgList.Sort
MissingList.Sort
Dim oText As String 'Added
For i As Integer = 0 To MissingList.Count - 1
	If i = 0 Then
		oText = MissingList(i)
		Else
			oText = oText & vbLf & MissingList(i)
Next
'---SHOW MISSING DWG LIST---
If oText = "" Then
	Else
RUsure = MessageBox.Show( _
	"No .dwg found for.." _
	& vbLf & "" _
	& vbLf & oText _
	& vbLf & "" _
	& vbLf & "Continue?", "Notice", MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
	For Each dwgName In dwgList
		Call PrintDocument(DwgPath)
	Next
End Sub
Function PrintDocument(DwgPath As String)
	Dim OpenVisible As Boolean = True
	Dim oDrawDoc As DrawingDocument = ThisApplication.Documents.Open(DwgPath, OpenVisible)
	Dim oPrintMgr As PrintManager = oDrawDoc.PrintManager
	With oPrintMgr
		.Printer = "\\lse-cep-data\Copier Office"
		.AllColorsAsBlack = True
		.ScaleMode = kPrintBestFitScale
		.ColorMode = kPrintDefaultColorMode
		.PrintRange = kPrintAllSheets
		.NumberOfCopies = 1
		.Orientation = kLandscapeOrientation
'		.PaperSize = oPaperSize
		.SubmitPrint
	End With
	oDrawDoc.Close
End Function
Any help appreciated!
Replies (10)
Message 2 of 11
Stakin
should get sheetsize to assign it,or assign it to the size which printer can accept
Message 3 of 11
skyleWX4C5
Thanks! I uncommented the paper size, but theres still the issue of the error on Line 69:
Message 4 of 11
Stakin
		Call PrintDocument(Dwgname)
	Next
Message 5 of 11
ryan.rittenhouse
Generally when I see that error for a Document Open it's because the file path is not correct. Try logging the path and make sure that the file it's pointing too has that exact name is in the right place.
Logger.Info(DwgPath)
If this solved your problem, or answered your question, please click Accept Solution.
Message 6 of 11
skyleWX4C5
This did help to clear the error, ran the code a couple times just to verify. The biggest issue that I still have is that the overall intention behind putting the files into an array didn't actually work. When run, the code does iterate through all parts and assemblies and prints them all. It does NOT print them in order. At least not by part number. I don't actually see a rhyme or reason to how its printing currently. Heres the updated code:
Sub Main
Exit Sub
numFiles = 0
			Else
Next
dwgList.Sort
MissingList.Sort
	If i = 0 Then
		Else
Next
If oText = "" Then
	Else
	& vbLf & "" _
	& vbLf & oText _
	& vbLf & "" _
Return
Else
	Next
End Sub
'	Dim oDrawDoc As DrawingDocument = ThisApplication.Documents.Open(DwgPath, OpenVisible)
	With oPrintMgr
		.NumberOfCopies = 1
		.SubmitPrint
	End With
	oDrawDoc.Close
End Function
Thanks !
Message 7 of 11
ryan.rittenhouse
If you want them sorted by part number, the off the cuff answer I have is to stuff them in a sorted dictionary with the part number as the key. Then you can iterate through the dictionary and get the files out in order. Something like this:
'Create a sorted dictionary to store part number and file name
Dim dwgDictionary As New SortedDictionary(Of String, String) ' {partNumber, fileName}
	Dim partNumber As String = oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	'Add partnumbers and file names to the dictionary
	dwgDictionary.Add(partNumber, dwgPathName)
Next oRefDoc
'Loop through the dictionary to create the prints in order by partnumber
For Each dwg As KeyValuePair(Of String, String) In dwgDictionary
	Call PrintDocument(dwg.Value)
Next dwg
Message 8 of 11
Stakin
			Else
Next
dwgList.Sort() Rem Thisline is sort by filename.,if you want to print by partnumber order,you should change dwg file name to part number format.
MissingList.Sort()
oText = String.Join(vbLf, dwgList.ToArray)
Rem Please check,the dwglist is be ordered by file name or not?If not,should sort it without directory.
Logger.Info(oText)
Message 9 of 11
skyleWX4C5
There it is! Thanks for all your help! This worked like a charm, however there's one more thing I'd like to change that I think should be a pretty easy fix. Hoping to work it into the code--I don't want the assembly files to print, only parts. Heres the updated code with your suggested method:
Sub Main
Exit Sub
numFiles = 0
			Else
Next
dwgList.Sort
MissingList.Sort
	If i = 0 Then
		Else
Next
If oText = "" Then
	Else
	& vbLf & "" _
	& vbLf & oText _
	& vbLf & "" _
Return
Else
Next dwg
End Sub
	With oPrintMgr
		.NumberOfCopies = 1
		.SubmitPrint
	End With
	oDrawDoc.Close
End Function
Thanks again!
Message 10 of 11
ryan.rittenhouse
You can add a check right inside your for loop to check the definition type
	If Not TypeOf oRefDoc.ComponentDefinition Is PartComponentDefinition Then Continue For
Message 11 of 11
skyleWX4C5
Perfect! Works great. Thanks!
