Save2 API causing Inventor Crash
Harshil.JAINS8RVT
Harshil.JAINS8RVT
Hello All,
I have been doing some operations in Inventor 2023 programatically.
As I have a large assembly having 1700 parts so I have been using Save2 API to Save it.
But this API is failing for the main assembly, and Inventor has crashed.
Could you please help me to fix this issue and handle the error so Invenor won't crash?
This is very urgent.
I have been calling the API from C++. Also, using MethodSave2 API would make any difference instead of Save2?
Thanks in advance for your help
JelteDeJong
You give very little inforation to go on. But if you are running Inventor on Windows 11 (24H2) you might want to have a look at the Inventor update 2023.5.3
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=Inventor_ReleaseNotes_updates_2023_5_3_fixed_b...
Jelte de Jong
Blog: hjalte.nl - github.com
Vaibhav_Agale
Community Visitor
Community Visitor
Hello  JelteDeJong,
We have been testing with Inventor update 2023.5.3 with Windows 10 (most customers still use Windows 10).
Is there a known bug/limitation from windows 10 side which has been fixed/not limited on windows 11?
Thank you!
