Balloon renumber
Balloon renumber
damjan_baraga
Message 1 of 12
Balloon renumber
damjan_baraga
I want to make an i-logic rule as is in the video below. Briefly, I put assembly on drawing and some parts from that assembly and then I want to renumber balloons of those parts as is item number in part list.
https://www.youtube.com/watch?v=AuewlPrm0VY&ab_channel=easytoolsno
Replies (11)
Message 2 of 12
damjan_baraga
I should add, that in case if part is not in Part list put letter X in Balloon
Message 3 of 12
damjan_baraga
I manage to make I-logic code, but its not working.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
Dim oSheet As Inventor.Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
For Each oSheet In oDrawDoc.Sheets
oViews = oSheet.DrawingViews
For Each oView In oViews
If oView.ViewType <> 10504 Then ' Not kProjectedDrawingViewType
' Get the full filename of the view model
Dim oModelFileName As String
oModelFileName = oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
Dim oPartList As PartsList
' Try to get the parts list from the table of this sheet
Try
oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
Catch ' On error, try and search all sheets for the first found parts list
' Iterate through each sheet
Dim i As Long
For i = 1 To oDrawDoc.Sheets.Count
If oDrawDoc.Sheets.Item(i).PartsLists.Count > 0 Then Exit For
Next
If oSheet.PartsLists.Count = 0 Then
MessageBox.Show("No Parts List found in the drawing.")
Exit Sub
End If
oPartList = oDrawDoc.Sheets.Item(i).PartsLists.Item(1)
End Try
' Iterate through the contents of the parts list.
Dim oRow As PartsListRow
Dim oRowFileName As String
Dim j As Long
For j = 1 To oPartList.PartsListRows.Count
' Get the current row
oRow = oPartList.PartsListRows.Item(j)
' Get filename of model in row
oRowFileName = oRow.ReferencedFiles.Item(1).FullFileName
' Compare the filenames
If StrComp(oModelFileName, oRowFileName, CompareMethod.Text) = 0 Then
' Get the value of Item from the Parts List (first item in the row)
Dim oItemValue As String
oItemValue = oRow.Item(1).Value
' Iterate through all the balloons in the sheet
Dim oBalloons As Balloons
Dim oBalloon As Balloon
oBalloons = oSheet.Balloons
For Each oBalloon In oBalloons
' Access the component that the balloon is attached to
Dim oBalloonComponent As ComponentOccurrence
oBalloonComponent = oBalloon.ReferencedComponent
' If the balloon is attached to the correct component, update the balloon text
If Not oBalloonComponent Is Nothing Then
If StrComp(oBalloonComponent.Definition.Document.FullFileName, oModelFileName, CompareMethod.Text) = 0 Then
' Set the balloon text to the item number (part number)
oBalloon.Text = oItemValue
End If
End If
Next
End If
Next
End If
Next
Next
MessageBox.Show("Balloon renumbering finished!")
Message 4 of 12
chicco199
Message 5 of 12
damjan_baraga
Thanks for the suggestion. I already tried it, but this code is not working even with a lot of modifications.
Message 6 of 12
chicco199
You can go around the corner and create a new user value that will match the values ​​from the main assembly. You can copy the values ​​either in the specification or Ilogic.
Sorry for my language.
Message 7 of 12
jnowel
I've edited your code a bit to make it work (though haven't tested it intensively)
I think the oView For-Loop is unnecessary, so had it removed.
	Try
		oPartList = oSheet.PartsLists.Item(1)
		Dim i As Long
		Next
			Exit Sub
		End If
	End Try
	For Each oBalloon In oSheet.Balloons
		Dim j As Long
			'Iterate and Get filename of model in row
			'iterating component definitions in case you have a 'merged' row
			For Each oCompDef As ComponentDefinition In oRow.ReferencedRows(1).BOMRow.ComponentDefinitions
				'Used "FullDocumentName" instead of "FullFileName" to handle components with Model states
				'if "FullFileName" is used, then you can't differentiate if you used the same component with different model states in your assy
				oRowFileName = oCompDef.Document.FullDocumentName
				Dim oBalloonComponent As DocumentDescriptor
				oBalloonComponent = oBalloon.ParentView.ReferencedDocumentDescriptor
				'Balloon override only works on if the Balloon.ParentView is a Component of PartsList Referened Document
				If StrComp(oBalloonComponent.FullDocumentName, oRowFileName, CompareMethod.Text) = 0 Then
					If oBalloon.BalloonValueSets(1).OverrideValue <> oBalloon.BalloonValueSets(1).ItemNumber Then
						oBalloon.BalloonValueSets(1).OverrideValue = oItemValue
					End If
				End If
			Next
		Next
	Next
Next
Message 8 of 12
damjan_baraga
So far, It`s works. Now I must figure out how to put X in Balloons, which are not in Part list
Message 9 of 12
jnowel
You can just check the balloon's parent view document then compare it with the parts list's document.
added another boolean variable bIsInPartsList and some lines
	Try
		Dim i As Long
		Next
			Exit Sub
		End If
	End Try
		Dim bIsInPartsList As Boolean = False
		If oBalloon.ParentView.ReferencedDocumentDescriptor.FullDocumentName = oPartList.ReferencedDocumentDescriptor.FullDocumentName Then
			'these are for balloons attached to the view of the main parts list
			bIsInPartsList = True
		End If
		Dim j As Long
					End If
				End If
			Next
		Next
		If Not bIsInPartsList Then
			oBalloon.BalloonValueSets(1).OverrideValue = "X"
		End If
	Next
Next
Message 10 of 12
damjan_baraga
Something strange is happening. If is Item same number as should be renumbered, thet renumbering is not done. In the picture you can see pos 8 from Part list. That should be overridden with 8 but stay 1.
Message 11 of 12
jnowel
try changing the if statement  (line 60-62) to this:
If oBalloon.BalloonValueSets(1).ItemNumber <> oItemValue Then
End If
Message 12 of 12
damjan_baraga
Here is whole working code. jnowel, Thank`s
	Try
		Dim i As Long
		Next
			Exit Sub
		End If
	End Try
		End If
		Dim j As Long
				End If
			Next
		Next
		' If the balloon is not a Component of PartsList Referened Document
		End If
	Next
Next
'MessageBox.Show("Balloon renumbering finished!")
