Automation of repeatable parts
SRayne44
SRayne44
Good Morning,
I have a problem I've been trying to solve for ages now.  In our company we build products called Vane Packs.  The packs are a collection of "Vane Blades" cut to length (straight end cut) to fit in a specific inner diameter.
Every blade is the same geometry, the only thing that changes is the length and distance (offset) from center line.  I have tried to automate this many times using master sketches with each profile for each blade and then extruding each as a surface, but the bigger it gets the slower it updates and the more snippet code I need to write to suppress a surface if it falls outside of the Inner Diameter.
Is there a way that I can just have 1 master Blade part, that can be added into an assembly with the length and offset being the only things that really change?
Any help/input would be awesome, as I'm at my wits end trying to figure this out.
Attached is an image of the product in question.
WCrihfield
How do you currently create these parts?  From scratch, partially manually & partially by code ; or entirely by code.  Are you creating each as a 'New' document from a Template, or are you copying an existing model document, then modifying?  Is each 'Vane' a separate Part, or is the model in the image a multi-body part?
My first thoughts would be to have a master part file (as an actual Template), then through use all named user parameters, a Form, and iLogic rules, to create a configuration Template part.  Then just click New, fill out Form, rules then run, and boom new model to specs.  But it may take a lot of work to get to that point.
Wesley Crihfield
(Not an Autodesk Employee)
SRayne44
I currently have a Master sketch file, with a Shell Diameter, a sketch of the blade profile which is patterned off center by the spacing required.  This pattern exceeds (on purpose) the Shell diameter up to a number of blades I consider a maximum (150 left, 150 right), inside that Master sketch in Ilogic I have a rule that calculates each blades length as it gets closer to the edge of the Shell Diameter, and any blades that fall outside that are left with a uncalculated dimension.
From there I derived an .ipt file from the Master and painfully extruded a surface for each of the blade lengths (150 left, 150 right), and then had to write a rule that if any blades fell outside the shell diameter that the surface extrusion was suppressed.  This process however takes probably 15-25 mins to update anytime the shell diameter is changed.  Which just doesn't help workflow at all and I could draw it in 2D cad in 1/4 of that time.
Attached is a sample of the master file and a sample image of the derived .ipt file.
WCrihfield
Wow.  That looks a lot more complicated that I had imagined.  Without having any of your product knowledge about this or having all the specifics of your design intent, this kind of seams like it might be a bigger task that I would want to take on remotely.  You may have to break this task down into smaller 'bite size' chunks and tackle it one step at a time, if you want help fully automating it.  Just my opinion though.  There are lots of others here on the forums that may be able to tackle a larger task like this though.
Wesley Crihfield
Michael.Navara
This is very nice task😀
This automation task is my core business and I can help you with it. If you are interested, you can contact me in private message.
Here is few information and samples
https://www.cadstudio.cz/en/csconfigurator.asp
