Automatic volume adjustment method.
smkang
Message 1 of 1
smkang
In a multi-body part, if one of the solids changes shape and changes volume, can the other solids also change shape in the same volume by automatically adjusting certain parameters?
For example, if the current volumes of "Solid_1" and "Solid_2" are the same, when the "D1" parameter of "Solid_1" is modified, the parameters of "Dia1" and "Dia2" of "Solid_2" are automatically modified and "Solid_1" "Can you match it to the same volume?
Replies (0)
