Automatic sheet generation for .idw
BK-MTFNE
Message 1 of 11
BK-MTFNE
Ok so I cobbled this iLogic together for my needs but it is failing at line 25 with the following error code and I cant find anything to make it work. any help would be appreciated.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
' Check if the active document is a drawing referencing a model
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
    MessageBox.Show("This rule is intended for drawings only.", "Error")
    Return
End If
' Get the referenced model document
Dim modelDoc = ThisDrawing.ModelDocument
' Check if the referenced document is a part or assembly
If modelDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject AndAlso
    modelDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
    MessageBox.Show("This rule is intended for drawings referencing parts or assemblies only.", "Error")
    Return
End If
' Continue with the rest of the code...
' Get the active assembly drawing document
Dim asmDoc As AssemblyDocument = oDoc
' Find the sheet format named "24 x 36"
Dim sheetFormatName As String = "24 x 36"
Dim sheetFormat As SheetFormat = Nothing
For Each sf As sheetFormat In oDoc.SheetFormats
    If sf.Name = sheetFormatName Then
        sheetFormat = sf
        Exit For
    End If
Next
' Check if the sheet format was found
If sheetFormat Is Nothing Then
    MessageBox.Show("Sheet format '24 x 36' not found.", "Error")
    Return
End If
' Loop through the parts in the assembly
For Each partOccurrence As ComponentOccurrence In asmDoc.ComponentDefinition.Occurrences
    ' Get the part document for each component occurrence
    If partOccurrence.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
        Dim partDoc As PartDocument = partOccurrence.Definition.Document
        ' Create a new sheet using the specified sheet format
        Dim newSheet As Sheet = oDoc.Sheets.AddUsingSheetFormat(sheetFormat)
        ' Set the sheet name to the part name
        newSheet.Name = partDoc.DisplayName
        ' Activate the new sheet
        newSheet.Activate()
        ' Add the part view to the new sheet
        Dim partView As DrawingView = oDoc.ActiveSheet.DrawingViews.AddBaseView(partOccurrence, Nothing, Nothing, Nothing, Nothing)
    End If
Next
' Activate the first sheet
oDoc.Sheets.Item(1).Activate()
Replies (10)
Message 2 of 11
A.Acheson
Hi @BK-MTFNE
So the error is that you are trying to set the Assembly Document Object (asmDoc)  = to the Drawing Document Object (oDoc)
This is wrong. What you actually need is the model document (modeldoc) which you allready have so you could remove this line.
In fact you may need to check if the model document is an assembly before you try use it in an assembly application. Later on I see you are looping through assembly occurrences and creating views using the occurrence. This wouod beed to be a document object. I would suggest you do this by ReferencedDocuments as this will give you one document reference immediately.  It has the added benefit of being more efficient instead of trying to dig down through the occurrence definition and through all of the multiple occurrences.
Here is a sample for ReferenceDoument Method
Sub Main
Dim assyDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Iterate through all Referenced Documents in the assembly.
For Each refDoc As Document In assyDoc.AllReferencedDocuments
	Logger.Info("Display Name Before Check: " & refDoc.DisplayName)
	' Check if the document is a sheet metal part.
    If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
	   partDoc = TryCast(refDoc,PartDocument)
		Logger.Info("Display Name:" & partDoc.DisplayName)
    End If
Next
End Sub
Regards
Alan
Message 3 of 11
BK-MTFNE
Thank you @A.Acheson for getting back to me, I have attempted to make the changes you referenced however I am not nearly proficent enough in iLogic to make it work. I am thinking I will need to skip this iLogic and come back to it at a later date when I have become more proficient in coding. Again thank you for your help.
Message 4 of 11
A.Acheson
Here is the method you were trying with the reference documents implemented. I have not tested this so you may find errors. It will assume your first view is an assembly.
And here is the API help for drawings views. There is alot to learn here so I would suggest to review the samples in there too. Knowing the options to change is the key to getting the views customized.
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
If doc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
    Return
End If
        sheetFormat = sf
        Exit For
    End If
Next
    Return
End If
' Create a new NameValueMap object
Dim baseViewOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
baseViewOptions.Add("DesignViewAssociative", True)
Dim modelDoc As Document= ThisDrawing.ModelDocument
For Each refDoc As Document In modelDoc.AllReferencedDocuments
        Dim newSheet As Sheet = doc.Sheets.AddUsingSheetFormat(sheetFormat)
        newSheet.Activate()
       ' Create the placement point object.
       Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
       ' Create a base view.
       Dim baseView As DrawingView = doc.ActiveSheet.DrawingViews.AddBaseView(oModel,oPoint,2,kIsoTopLeftViewOrientation,kHiddenLineRemovedDrawingViewStyle,,baseViewOptions)
    End If
Next
Regards
Alan
Message 5 of 11
BK-MTFNE
Oh wow, I see where i was going wrong with the referenced documents. I fixed a couple errors that came up but I cant seem to figure out what is wrong on line 47
If it already found the sheet format earlier in the code I'm not sure why its saying  the parameter is incorrect. Is the sheet format name "24 x 36" supposed to be specifically called out?
Message 6 of 11
A.Acheson
Hi @BK-MTFNE
If you are using my code I changed around the variable name for the drawing document from oDoc to doc. I also spotted another error in the model document variable name. And also you can create views directly from the sheet format so no need for additional view creation.
See working code below.
    Return
End If
For Each sf As sheetFormat In doc.SheetFormats
        sheetFormat = sf
        Exit For
    End If
Next
    Return
End If
        Dim newSheet As Sheet = doc.Sheets.AddUsingSheetFormat(sheetFormat,refDoc,partDoc.DisplayName)
    End If
Next
doc.Sheets.Item(1).Activate()
Regards
Alan
Message 7 of 11
BK-MTFNE
@A.Acheson You are awesome, I cant thank you enough. this has been stumping me for awhile. It works perfect.
Message 8 of 11
A.Acheson
No problem at all. My first go at sheetformats so it will go in my list for implementation soon as it had a nice outcome on the drawings views.
Regards
Alan
Message 9 of 11
BK-MTFNE
@A.Acheson  This has been working flawlessly but i recently had an issue come up with a model where there are sub-assemblies. I would like it to also create the sheets for the sub-assemblies. I attempted to add the ability to do this a few ways but I keep crashing the iLogic. Is there something I'm missing that prevents this or am I just completely messing up.
For your information once I came across this line
 I was lost cause I can't find decent documentation on this type of iLogic.
Message 10 of 11
A.Acheson
If you want assemblies and parts then just remove the filter lines for parts only and use the more generic document class.
The new for statement
	'Logger.Info("Display Name Before Check: " & refDoc.DisplayName)
        Dim newSheet As Sheet = doc.Sheets.AddUsingSheetFormat(sheetFormat,refDoc,refDoc.DisplayName)
Next
The DocumentTypeEnum help page is here
And under document you will find its a property here
Regards
Alan
Message 11 of 11
BK-MTFNE
I was trying to add a "search" for  assemblies, I didnt think that the assemblies were filtered. It works perfectly. Also thank you for the links, I will definitely be studying them.
