Automatic Macro Running
Message 1 of 18
Hi all
I'm still looking for a solution, and I'm sure
it's there.
Is there any method of running a macro
automatically when I save a file?
Rui
Replies (17)
Message 2 of 18
Yes, you should use
the AutoSave:
This code should be add into the "Autodesk
Inventor Objects\ThisDocument" section.
Public Sub AutoSave_DoNothing()
    MsgBox "This macro do...
nothing"
End Sub
The message will be prompt each time you save the
file (replace the "DoNothig" with your function name).
Xavier
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi all
it's there.
Rui
Message 3 of 18
Excellent!! Thanks
Now for making my program better:
1. Can I add this to a template file so it's
available to all parts?
2. Can something similar be done so the program
runs when I commit a feature?
Thanks for the help so far.
Rui
Yes, you should
use the AutoSave:
nothing"
End Sub
Xavier
Hi all
it's there.
Rui
size=2>
Message 4 of 18
Ruif
You may want to read the Subject VBA creation started on the 18th of this month. Using
the Auto macros in your templates is not suggested. Also read the subject "A limit to
the # of VBA project loaded at one time?" thread started on the 16th
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"RuiF" wrote in message
news:[email protected]...
> Excellent!! Thanks
> 1. Can I add this to a template file so it's available to all parts?
> 2. Can something similar be done so the program runs when I commit a feature?
> Rui
> "Xavier Collet" wrote in message
> Yes, you should use the AutoSave:
> This code should be add into the "Autodesk Inventor Objects\ThisDocument" section.
> MsgBox "This macro do... nothing"
> End Sub
> The message will be prompt each time you save the file (replace the "DoNothig" with
> Xavier
> "RuF" a écrit dans le message de
> Hi all
> I'm still looking for a solution, and I'm sure it's there.
> Is there any method of running a macro automatically when I save a file?
> Thanks
> Rui
Message 5 of 18
Those are some of the reasons why I wanted to keep
this as an application macro.
Is there any way for a document macro to call an
application program to run?
At least then the document would contain very
little code.
Like I said, ideally, I would have an application
macro that ran every time a feature in a part was commited, but so far nobody
has been able to help me (added to the fact that I'm relatively new to IV and
VBA, the scenario doesn't get better).
I've been looking at transactions, although I'm
not sure if that's what I want.
Thanks in advance for any input you guys may
have.
Rui
Ruif
You
month.  Using
the # of VBA
16th
Kent
Assistant Moderator
Moderator Program
"RuiF" <
href="mailto:[email protected]">[email protected]
> wrote in
message
href="news:[email protected]">news:D2BA59B40BDB3BD6C3A7063FBBA...
Excellent!! Thanks
better:
to all parts?
far.
> Rui
>   "Xavier Collet" <
> wrote in message
href="news:[email protected]">news:8244FAFC61BED280D94AFFCBF2D...
>   This code should
section.
>   Public Sub
>       MsgBox "This
>   End Sub
with
Xavier
>     "RuF" <
> a écrit dans le
message de
href="news:[email protected]">news:149D88C0BC9E882FB314B824958...
Hi all
>     Is
file?
Rui
Message 6 of 18
In that thread I pointed you to Brian had posted a solution. Someone had a bit of a
problem with it so he said he was looking into improving the code as I remember. Might
want to reread the thread.
Kent
Assistant Moderator
> Those are some of the reasons why I wanted to keep this as an application macro.
> Is there any way for a document macro to call an application program to run?
Message 7 of 18
Thanks Kent
Hadn't seen the post in iCF.  Going to look
at that.
Rui
In
bit of a
want to reread the
thread.
Kent
Assistant Moderator
Moderator Program
"RuiF" <
> wrote in
message
href="news:[email protected]">news:14D83A200187C47B4409DB1B021...
macro.
Message 8 of 18
I wouldn't even recommend that.
I had a few hundred parts with nothing but a small
sub (3-4 lines) and it kept crashing VBA.  Inventor was fine but the VBA
environment couldn't handle it.
I'd look at making it an add-in. (which is what I
ended up doing with my document code)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
little code.
application macro that ran every time a feature in a part was commited, but so
far nobody has been able to help me (added to the fact that I'm relatively new
to IV and VBA, the scenario doesn't get better).
have.
Rui
Ruif
You
month.  Using
the # of VBA
16th
Kent
Assistant Moderator
Moderator Program
"RuiF" <
> wrote in
message
href="news:[email protected]">news:D2BA59B40BDB3BD6C3A7063FB...
Excellent!! Thanks
better:
> Thanks for the
help so far.
> Rui
>   "Xavier Collet"
<[email protected]> wrote in
message
href="news:[email protected]">news:8244FAFC61BED280D94AFFCBF...
>   This code
section.
>   Public Sub
>       MsgBox
>   End
Sub
your function
name).
>   Xavier
"RuF" <[email protected]> a
href="news:[email protected]">news:149D88C0BC9E882FB314B8249...
Hi all
file?
Rui
Message 9 of 18
I just posted an update of the utility in customer
files.
-Brian
Thanks Kent
at that.
Rui
In
a bit of a
want to reread the
thread.
Kent
Assistant Moderator
Autodesk Discussion
"RuiF" <
> wrote in
message
href="news:[email protected]">news:14D83A200187C47B4409DB1B0...
macro.
run?
Message 10 of 18
Not that I'm 100% sure of what an addin is
exactly, but I'm almost sure you can't do it with VBA can you?
Rui
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:[email protected]">news:EA60C71EEF80B6865DBDDFA5F69...
small sub (3-4 lines) and it kept crashing VBA.  Inventor was fine but
the VBA environment couldn't handle it.
Sean Dotson, PE
Check the Inventor
little code.
so far nobody has been able to help me (added to the fact that I'm
relatively new to IV and VBA, the scenario doesn't get better).
I'm not sure if that's what I want.
have.
Rui
Ruif
You
month.  Using
the # of VBA
16th
Kent
Assistant Moderator
Moderator Program
"RuiF" <
> wrote in
message
href="news:[email protected]">news:D2BA59B40BDB3BD6C3A7063...
Excellent!! Thanks
better:
> Thanks for
the help so far.
> Rui
>   "Xavier
Collet" <[email protected]>
wrote in message
href="news:[email protected]">news:8244FAFC61BED280D94AFFC...
>   This code
section.
>   Public Sub
>       MsgBox
>   End
Sub
your function
name).
>   Xavier
href="news:[email protected]">news:149D88C0BC9E882FB314B82...
Hi all
file?
Rui
Message 11 of 18
No you can't, it takes full blown VB, but Brians solution should work for you I would
think. It is a Addin
Kent
Assistant Moderator
> Not that I'm 100% sure of what an addin is exactly, but I'm almost sure you can't do it
with VBA can you?
> Rui
> "Sean Dotson" wrote in message
> I had a few hundred parts with nothing but a small sub (3-4 lines) and it kept
crashing VBA. Inventor was fine but the VBA environment couldn't handle it.
> I'd look at making it an add-in. (which is what I ended up doing with my document
code)
> Sean Dotson, PE
> Check the Inventor FAQ for most common questions
> At least then the document would contain very little code.
> Like I said, ideally, I would have an application macro that ran every time a
feature in a part was commited, but so far nobody has been able to help me (added to the
fact that I'm relatively new to IV and VBA, the scenario doesn't get better).
> I've been looking at transactions, although I'm not sure if that's what I want.
> Thanks in advance for any input you guys may have.
> Rui
> "Kent Keller" wrote in message
> Ruif
Using
limit to
> Kent
> Assistant Moderator
> > Excellent!! Thanks
> > Rui
section.
> > End Sub
with
> > Xavier
> > Hi all
> > Thanks
> > Rui
Message 12 of 18
Kent, he would still need to have the code to call the add-in in his
document project (if I understand Brian's example, I haven't downloaded it
yet).
If he puts this in bit of code in each and every part, sooner or later it's
going to blow up in any decent sized assy. I've been doing some more
reading on VBA's memory handling and it's not the best in the world...
Sean Dotson, PE
you I would
> Kent
> Assistant Moderator
you can't do it
> with VBA can you?
> > Rui
it kept
it.
my document
> code)
> > Sean Dotson, PE
application macro.
to run?
every time a
(added to the
better).
what I want.
> > Rui
> > Ruif
of this month.
> Using
the subject "A
> limit to
16th
> > Kent
> > Assistant Moderator
> > > Excellent!! Thanks
parts?
commit a feature?
> > > Rui
> section.
> > > End Sub
> with
> > > Xavier
> > > Hi all
save a file?
> > > Thanks
> > > Rui
Message 13 of 18
well I haven't had a chance to look at Brian's addin yet either, but as I understood it,
the program ran a normal macro such as in your default.ivb 8^) No need to have it in
every file. I am sure Brian will correct me if I am wrong
Kent
Assistant Moderator
> yet).
> Sean Dotson, PE
Message 14 of 18
Kent's right. This allows you to have an automatic macro in the default
ivb. This allows you to now do a lot of things with VBA that previously you
could only do using an Add-In.
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
understood it,
to have it in
> Kent
> Assistant Moderator
it
> > yet).
it's
> > Sean Dotson, PE
Message 15 of 18
Brian:
Great job, working perfectly ....
almost.
Probably me, or something I have done wrong, but
what I did was copy your clsEvents class module to my default ivb class
 module and I copied some of your code to create the macro I
wanted.
This is working perfectly, every time I save the
macro runs.
Problem: I had/have other modules with macros
assigned to buttons on toolbars.  The macros run OK from the MACRO, RUN
dialog, but when I click the button nothing happens.
Any clues?  Have I done something
wrong?
I attached a screen shot of my setup.
Rui
Kent's
default
previously you
Brian
Ekins
Discussion Q&A:
href="http://www.autodesk.com/discussion">http://www.autodesk.com/discussion
"Kent
Keller" <[email protected]>
wrote in message
href="news:[email protected]">news:54438BDA5167013E4A9CD9F6833...
I
understood it,
to have it in
> every
wrong<G>
> Kent
> Assistant
Moderator
Program
wrote in message
href="news:[email protected]">news:7F6FC8DD585F6C9EFB249A32D23...
his
downloaded
it
> > yet).
> > If he puts this
it's
more
the world...
> > Sean Dotson, PE
Message 16 of 18
Ah, gotcha. That's good. Don't want all that code running around in the
part files.
Sean Dotson, PE
"Brian Ekins (Autodesk)" wrote in message
you
> Brian Ekins
I
> understood it,
> to have it in
> > Kent
> > Assistant Moderator
downloaded
> it
> > > yet).
> it's
> > > Sean Dotson, PE
Message 17 of 18
Brian:
No clues as to why my other macros don't run via a
button now?
Rui
Brian:
almost.
wanted.
macro runs.
wrong?
setup.
Rui
Kent's
default
that previously you
Brian
Ekins
Discussion Q&A:
"Kent
wrote in message
href="news:[email protected]">news:54438BDA5167013E4A9CD9F68...
I
understood it,
to have it in
> every
wrong<G>
> Kent
> Assistant
Moderator
Program
href="news:[email protected]">news:7F6FC8DD585F6C9EFB249A32D...
his
haven't downloaded
it
> > yet).
> > If he
later
it's
Sean Dotson, PE
> > Check
Message 18 of 18
Hi Rui,
I was able to reproduce your problem and did a bit
of investigation and have found the problem.  It is related to this
Add-In.  When you start Inventor, my Add-In looks for and runs the
AutoStart macro.  In Inventor 7, the application project wasn't actually
loaded until the VBA editor was invoked.  Because of this my Add-In loaded
the application project.  However, Inventor became confused and thought
this was a user project since it had been loaded by someone else.  This
messes up Inventor being able to find macros that are associated with buttons
and also breaks the ability to add new buttons for macros.  The behavior in
Inventor 8 has already been changed so that if you access the VBA projects
through the API it will automatically force the loading of the application
project.  Because of this change, my Add-In works correctly with Inventor
8, although I'll probably post a newer version for 8 because I can actually
simplify my code quite a bit.
Brian Ekins
Developer Technical
Services, Autodesk
Discussion Q&A:
Brian:
a button now?
Rui
Brian:
almost.
but what I did was copy your clsEvents class module to my default ivb class
wanted.
the macro runs.
wrong?
setup.
Rui
Kent's
default
that previously you
Brian
Ekins
Discussion Q&A:
"Kent
Keller" <
> wrote in
message
href="news:[email protected]">news:54438BDA5167013E4A9CD9F...
I
understood it,
to have it in
> every
wrong<G>
> Kent
> Assistant
Moderator
Program
href="news:[email protected]">news:7F6FC8DD585F6C9EFB249A3...
his
haven't downloaded
it
> > yet).
> > If
later
it's
> > Sean Dotson, PE
