Automated PDF export question
machiel.veldkamp
Message 1 of 14
machiel.veldkamp
Hi guys,
I'm trying to improve our workflow a bit and I had a couple of Ideas
1 - I want to let the user pick the project they are working on and let iLogic place the PDF's in subfolders in that project.
2 - based on the filename (X-YYPZZZZ-001.dwg) I want iLogic to find the correct folder (we have folders with numbers in them)
3 - no user interaction; just press the button and iLogic will find out - based on the filenumber - where the drawing should be saved to.
So! I'm currently working on no. 1
I'll paste the whole code below but what I'm struggeling with at the moment is the point after I chose where to save the file.
'Ask which project the User uses
	oQuestion2 = InputListBox("Choose where", ProjectChoice, ProjectChoice, Title := "KIES PROJECT", ListName := "ProjectChooser")
the relevant piece of code is this:
'Choose Preselected Folder
	Dim oChoice
	Dim ProjectChoice As New ArrayList
	ProjectChoice.Add("Project 1")
	ProjectChoice.Add("Project 2")
	oFolder = "G:\folder\"& ProjectChoice(oChoice) &"\folder\"
	Dim Proc As String = "Explorer.exe"
	Dim Args As String = ControlChars.Quote & IO.Path.Combine("G:\", oFolder) & ControlChars.Quote
no matter what I choose, it will always save on the (0) value in the arraylist.
Any advise?
Here is the complete code I've written.
Public Sub Main()
	Dim oPath = ThisDoc.Path
	oFileName = ThisDoc.FileName(False) 'without extension
	oDuctName = iProperties.Value("Project", "Description")
	oRevNum = iProperties.Value("Project", "Revision Number")
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oDWGAddIn As TranslatorAddIn
	oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
	oDrafstman = ThisApplication.UserName
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMediumPDF = ThisApplication.TransientObjects.CreateDataMedium
	oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium
	Dim oChoice
	oFolder = "G:\COMPANYNAME\orders\2016\Projecten\"& ProjectChoice(oChoice) &"\Tekeningen Engineering\2D Tekeningen\"
	'PDF Setup
	If oPDFAddIn.HasSaveCopyAsOptions(oDataMediumPDF, oContext, oOptions) Then
		oOptions.Value("All_Color_AS_Black") = 0
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Vector_Resolution") = 500
		oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	' DWG SETUP - Check whether the translator has 'SaveCopyAs' options
	If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
		Dim strIniFile As String
		strIniFile = "G:\folder\INVENTOR\iLogic\Save as DWG aparte sheets.ini"
		' Create the name-value that specifies the ini file to use.
		oOptions.Value("Export_Acad_IniFile") = strIniFile
	'get  target folder path
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
		'Set the destination file name
	Dim fileName As String
	fileName = ThisDoc.FileName(False) & " - " & oDuctName & " - REV " & iProperties.Value("Project", "Revision Number")
	oDataMediumDWG.FileName = oFolder & fileName  & ".dwg"
	oDataMediumPDF.FileName = oFolder & fileName  & ".pdf"
	oQuestion2 = InputListBox("KIES HET PROJECT WAAR DE PDF/DWG MOET WORDEN OPGESLAGEN", ProjectChoice, ProjectChoice, Title := "KIES PROJECT", ListName := "ProjectChooser")
	'Ask the User if he wants PDF or PDF+DWG
	oQuestion =  MessageBox.Show("For PDF select YES         for PDF+DWG select NO", "PDF or PDF/DWG", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	'Publish document.
	If oQuestion = vbYes Then
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF)
		Else If oQuestion = vbNo Then
			oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumDWG)
			Else
			'MessageBox.Show("Canceled", "We're doing nothing now...")
	If oQuestion = vbYes Or oQuestion = vbNo Then
		OpenFolder=  MessageBox.Show("Would you open the folder?", "PDF EXPORTED", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
		'open the folder where the new files are saved
		If OpenFolder = vbYes Then
			Process.Start(Proc, Args)
			Else
			'Return
		Else
End Sub
___________________________
Replies (13)
Message 2 of 14
Ktomberlin
I believe its not working because you are setting oFolder before you ask the question and not resetting it based on your answer to Question2.  If you move the question2 up, it works in my testing.  Hope this helps.
Now for the second part I need a little more information on the file names to fully understand what your looking for, but you'll most likely need to use something like this to get the folder location calculated.
Dim PDF_Folder As String
Dim F_Finder As String
If iProperties.Value("Project", "Project")= NullString
    Goto CalculateIt
    Else
        F_Finder = (Mid(oFileName,2,3))
        PDF_Folder = (Left(iProperties.Value("Project", "Project"),4))
    Dim oChoice
    oFolder = "C:\Temp\"& oQuestion2 &"\Tekeningen Engineering\2D Tekeningen\"
    'oFolder = "C:\Temp\"& ProjectChoice(oChoice) &"\Tekeningen Engineering\2D Tekeningen\"
Message 3 of 14
machiel.veldkamp
This is great! Thank you for the help. I didn't think about the order before so thanks for that.
Message 4 of 14
machiel.veldkamp
Hi @Ktomberlin
Just to finnish the topic:
SyntaxEditor Code Snippet
    'Beginning of the Code'
    Dim FolderNameLoc As String
    'Declare projects in the 2016 Projects Folder
    Dim oChoice
    ProjectChoice.Add("HOME") 'Drawings will be saved on a seperate location
    ProjectChoice.Add("ProjectExample1")
    ProjectChoice.Add("ProjectExample2")
    oQuestion2 = InputListBox("Project specification - in doubt select HOME", ProjectChoice, ProjectChoice, Title := "CHOOSE PROJECT", ListName := "ProjectChooser")
    FolderNameLoc = Mid(oPath, InStrRev(oPath , "\"))
    If oQuestion2 = "HOME"
        oFolder = "G:\CompanyName\INVENTOR\Save As PDF DWG location\" & oDrafstman & "\"
        Else
            oFolder = "G:\CompanyName\orders\2016\Projecten\"& oQuestion2 &"\Tekeningen Engineering\2D Tekeningen"& FolderNameLoc & "\"
 This is the relevant piece of code.
Message 5 of 14
Can this be used for printing all sheets as individual PDFs?
Message 6 of 14
This is what I have:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 38787 StartFragment: 314 EndFragment: 38755 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main
    Dim IPJ as String
    Dim IPJ_Name As String
    Dim IPJ_Path As String
    Dim FNamePos As Long
    'set a reference to the FileLocations object.
    IPJ = ThisApplication.FileLocations.FileLocationsFile
    'get the location of the last backslash seperator
    FNamePos = InStrRev(IPJ, "\", -1)
    'get the project file name with the file extension
    IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
    'get the project name (without extension)
    IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4)
    'get the path of the folder containing the project file
    IPJ_Folder_Location = Left(IPJ, Len(IPJ) - Len(IPJ_Name))
    MessageBox.Show("Would you like to print to the current Project Folder?" & vbLf & "Project Name:" & IPJ_Name _
    & vbLf & "Project Path:" & IPJ_Folder_Location _
     ,"iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
    Dim i As Integer
    iLogicVb.RunRule("CustOn")
    oFolder = Left(ThisDoc.Path, InStrRev(oPath, "\")) & "PDF"
    'Check for the PDF folder and create it if it does not exist
    Dim fname As String
    Dim PrintedSheets as String
        For i=1 To ThisDrawing.Document.sheets.count
            ActiveSheet = ThisDrawing.Sheet(ThisDrawing.Document.Sheets(i).Name)
            fname = oFileName & "-sht"& i  & "-Rev" & oRevNum & " .pdf"
            printedSheets = fname & vbCrLf & printedSheets
            printsheet (oFolder,fname)
        Next i
        'iProperties.Value("Custom", "2Shop ShtTotal")= Chr(i + 64)
    MessageBox.Show("Print Created in default Projects -  " &  oFolder & " \" &  vbCrLf & vbCrLf & printedSheets , "Inventor")
End Sub
Function PrintSheet(sheetPath As String, sheetName As String  )
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
     Dim oContext As TranslationContext
    oContext.Type = kFileBrowseIOMechanism
    'Create a NameValueMap object
    Dim oOptions As NameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
        If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
        'oOptions.Value("Launch_Viewer") = launchviewer
        oOptions.Value("All_Color_AS_Black") = 1
        'oOptions.Value("Sheet_Range") = ThisApplication.PrintRangeEnum.kPrintAllSheets
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    'get PDF target folder path
     'Set the PDF target file name
    oDataMedium.FileName = sheetPath & "\" & sheetName
    'Publish document.
    If  System.IO.Directory.Exists( sheetPath & "\" & sheetName ) Then
        System.IO.File.Delete( sheetPath & "\" & sheetName )
        MessageBox.Show("Earlier PDF deleted! ", "Inventor")
    PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Function
I want the message box to control where the PDFs go. So if yes it goes to the project file, and if no you can manually map it to any folder like a "Save As" command
Message 7 of 14
machiel.veldkamp
Yeah I have that bit of code at work. The code shown at this thread and att the other I just posted lack THAT tiny bit of code.
I'm not behind a powerfull PC with a working version of Inventor so best I can do is send you that first thing monday. (I'm in europe)
Message 8 of 14
machiel.veldkamp
Public Sub Main()
    Dim oFilePath As String
    Dim dialog As New FolderBrowserDialog()
    Dim ProjYear As String
    Try 'Get FolderName for current file
        Catch
            MessageBox.Show("Save the Document First","Error" ,MessageBoxButtons.OK, MessageBoxIcon.STOP)
            Exit Sub
    End Try
        ProjectChoice.Add("CUSTOM") 'Choose where to save files
            'Custom Folders from here on.
        ProjectChoice.Add("Custom Folder 1")
        ProjectChoice.Add("Custom Folder 2")
        ProjectChoice.Add("Custom Folder 3")
        ProjectChoice.Add("Custom Folder 4")
    ProjectChooser = InputListBox("Project specification - in doubt select HOME", ProjectChoice, ProjectChoice, Title := "CHOOSE PROJECT", ListName := "ProjectChooser")
    If ProjectChooser = "HOME" Then
        oFolder = "G:\TEMP\" & oDrafstman & "\"
        ElseIf ProjectChooser = "CUSTOM" Then
            If dialog.ShowDialog() = dialogresult.ok
                oFolder = dialog.SelectedPath & "\"
                Else
                    Exit Sub
        Else 'Choosing a Project
            Try
                ProjYear = Left(ProjectChooser,2) ' Read the ProjectYear (valid until the year 2100)
            Catch
                MessageBox.Show("Wrong Project. Ask ADMIN to fix the Code", "ERROR #ProjYear")
            End Try
            oFolder = "C:\TEMP\20" & ProjYear & "\Projecten\"& ProjectChooser &"\Tekeningen Engineering\2D Tekeningen"& FolderNameLoc & "\"
    Dim Args As String = ControlChars.Quote & oFolder & ControlChars.Quote
        'PDF Setup
        oOptions.Value("All_Color_AS_Black") = 0 '0 = color // 1 = black
        oOptions.Value("Remove_Line_Weights") = 1 'boolean
        strIniFile = "G:\TEMP\Save as DWG aparte sheets.ini"
    fileName = ThisDoc.FileName(False) & " - " & oDuctName & " - REV " & oRevNum
        'Publish document.
            Else
        OpenFolder =  MessageBox.Show("Would you open the folder? Files saved in:       " & oFolder, "PDF EXPORTED", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
            Else
        Else
End Sub
alright. so as promised here is the finished code as we are using it right now. I edited some project specific locations to C:\TEMP
Message 9 of 14
So using this can I have it mapped per project file?
Message 10 of 14
machiel.veldkamp
Not per project FILE. Per project yes.
Message 11 of 14
Ok, so this will basically map itself to where the project is?
Because what I need to do is for the code to print all the sheets as individual PDF's in a PDF folder mapped to where the project is. And if you are not wanting the project you can map it.
Message 12 of 14
machiel.veldkamp
Play around with it. Learn
Message 13 of 14
So I was able to figure out everything except individual sheets. Do you have any experience with that?
Message 14 of 14
machiel.veldkamp
Not persé, however I thought of something...
you could do a for each loop for the
part. Haven't done that. Maybe there is a better way. Easiest thing is to look it up in the API.
