- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys,
I'm trying to improve our workflow a bit and I had a couple of Ideas
1 - I want to let the user pick the project they are working on and let iLogic place the PDF's in subfolders in that project.
2 - based on the filename (X-YYPZZZZ-001.dwg) I want iLogic to find the correct folder (we have folders with numbers in them)
3 - no user interaction; just press the button and iLogic will find out - based on the filenumber - where the drawing should be saved to.
So! I'm currently working on no. 1
I'll paste the whole code below but what I'm struggeling with at the moment is the point after I chose where to save the file.
'Ask which project the User uses oQuestion2 = InputListBox("Choose where", ProjectChoice, ProjectChoice, Title := "KIES PROJECT", ListName := "ProjectChooser")
the relevant piece of code is this:
'Choose Preselected Folder Dim oChoice Dim ProjectChoice As New ArrayList ProjectChoice.Add("Project 1") ProjectChoice.Add("Project 2") oFolder = "G:\folder\"& ProjectChoice(oChoice) &"\folder\" Dim Proc As String = "Explorer.exe" Dim Args As String = ControlChars.Quote & IO.Path.Combine("G:\", oFolder) & ControlChars.Quote
no matter what I choose, it will always save on the (0) value in the arraylist.
Any advise?
Here is the complete code I've written.
Public Sub Main() Dim oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oDuctName = iProperties.Value("Project", "Description") oRevNum = iProperties.Value("Project", "Revision Number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") Dim oDWGAddIn As TranslatorAddIn oDWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}") oDrafstman = ThisApplication.UserName oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMediumPDF = ThisApplication.TransientObjects.CreateDataMedium oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium 'Choose Preselected Folder Dim oChoice Dim ProjectChoice As New ArrayList ProjectChoice.Add("Project 1") ProjectChoice.Add("Project 2") oFolder = "G:\COMPANYNAME\orders\2016\Projecten\"& ProjectChoice(oChoice) &"\Tekeningen Engineering\2D Tekeningen\" Dim Proc As String = "Explorer.exe" Dim Args As String = ControlChars.Quote & IO.Path.Combine("G:\", oFolder) & ControlChars.Quote 'PDF Setup If oPDFAddIn.HasSaveCopyAsOptions(oDataMediumPDF, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 500 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets End If ' DWG SETUP - Check whether the translator has 'SaveCopyAs' options If oDWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "G:\folder\INVENTOR\iLogic\Save as DWG aparte sheets.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'get target folder path If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the destination file name Dim fileName As String fileName = ThisDoc.FileName(False) & " - " & oDuctName & " - REV " & iProperties.Value("Project", "Revision Number") oDataMediumDWG.FileName = oFolder & fileName & ".dwg" oDataMediumPDF.FileName = oFolder & fileName & ".pdf" 'Ask which project the User uses oQuestion2 = InputListBox("KIES HET PROJECT WAAR DE PDF/DWG MOET WORDEN OPGESLAGEN", ProjectChoice, ProjectChoice, Title := "KIES PROJECT", ListName := "ProjectChooser") 'Ask the User if he wants PDF or PDF+DWG oQuestion = MessageBox.Show("For PDF select YES for PDF+DWG select NO", "PDF or PDF/DWG", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) 'Publish document. If oQuestion = vbYes Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF) Else If oQuestion = vbNo Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumPDF) oDWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMediumDWG) Else 'MessageBox.Show("Canceled", "We're doing nothing now...") End If If oQuestion = vbYes Or oQuestion = vbNo Then OpenFolder= MessageBox.Show("Would you open the folder?", "PDF EXPORTED", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) 'open the folder where the new files are saved If OpenFolder = vbYes Then Process.Start(Proc, Args) Else 'Return End If Else End If End Sub
___________________________Solved! Go to Solution.
