Message 1 of 8
Automated Mates
- Mute
- Permalink
- Report
Hello everyone,
I'm working on placing .ipt and .iam files into an assembly and want to create an iLogic rule that mates the objects to the origin — but at the position and orientation where they're placed.
That means I don’t want the components to move to the origin or be grounded; instead, they should be locked in place exactly where and how they were inserted. This will apply to multiple parts placed into the assembly simultaneously.
Below is the code I received from Grok, but I'm running into errors. Unfortunately, I'm not very experienced with coding, so I’d really appreciate any help in figuring this out.
Thanks so much in advance!!!
Dim oAsm As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim asmXY As WorkPlane = oDef.WorkPlanes.Item("XY Plane")
Dim asmYZ As WorkPlane = oDef.WorkPlanes.Item("YZ Plane")
Dim asmXZ As WorkPlane = oDef.WorkPlanes.Item("XZ Plane")
For Each oOcc As ComponentOccurrence In oDef.Occurrences
If oOcc.Grounded Then Continue For
' Optional: Temporarily skip known problematic components
' If oOcc.Name = "P25237-CMS-QTS-QTS-RIC2:1" Or oOcc.Name = "25237-WALL-1" Then Continue For
Dim compDef As Object = oOcc.Definition
Dim xyPlane As WorkPlane = Nothing
Dim yzPlane As WorkPlane = Nothing
Dim xzPlane As WorkPlane = Nothing
' Check component type and retrieve work planes
If TypeOf compDef Is PartComponentDefinition Then
Dim partDef As PartComponentDefinition = compDef
xyPlane = TryCast(partDef.WorkPlanes.Item("XY Plane"), WorkPlane)
yzPlane = TryCast(partDef.WorkPlanes.Item("YZ Plane"), WorkPlane)
xzPlane = TryCast(partDef.WorkPlanes.Item("XZ Plane"), WorkPlane)
ElseIf TypeOf compDef Is AssemblyComponentDefinition Then
Dim asmDef As AssemblyComponentDefinition = compDef
xyPlane = TryCast(asmDef.WorkPlanes.Item("XY Plane"), WorkPlane)
yzPlane = TryCast(asmDef.WorkPlanes.Item("YZ Plane"), WorkPlane)
xzPlane = TryCast(asmDef.WorkPlanes.Item("XZ Plane"), WorkPlane)
Else
MessageBox.Show("Unsupported component type: " & oOcc.Name)
Continue For
End If
' Skip if any plane is missing
If xyPlane Is Nothing Or yzPlane Is Nothing Or xzPlane Is Nothing Then
MessageBox.Show("Missing work plane for: " & oOcc.Name)
Continue For
End If
' Check component state
If oOcc.Suppressed Then
MessageBox.Show("Component suppressed: " & oOcc.Name)
Continue For
End If
If oOcc.IsPatternElement Then
MessageBox.Show("Component in pattern: " & oOcc.Name)
Continue For
End If
' Apply flush constraints
Try
oDef.Constraints.AddFlushConstraint(asmXY, xyPlane, 0)
oDef.Constraints.AddFlushConstraint(asmYZ, yzPlane, 0)
oDef.Constraints.AddFlushConstraint(asmXZ, xzPlane, 0)
oOcc.Grounded = False
Catch ex As Exception
Dim compType As String = If(TypeOf compDef Is PartComponentDefinition, "Part", "Assembly")
MessageBox.Show("Constraint error with: " & oOcc.Name & vbCrLf & _
"Type: " & compType & vbCrLf & _
"Details: " & ex.Message & vbCrLf & _
"Source: " & ex.Source)
Continue For
End Try
Next
