Automated & Prompted Drawing View Scale
MrSmithtastic
Message 1 of 1
MrSmithtastic
OK so I did some digging and found a few bits of code that all did almost what I was looking for. But none were quite there.
I just wanted to share this little rule with everyone.
This assumes that you've got a title block on your drawing with a prompted entry for sheet scale called <Scale>.
If you then create a rule in your document with this code it will bring a prompt up for each drawing sheet consecutively. If you simply hit ok leaving "ignor" in the inputBox it will bring through the scale of the first drawing view to the title block. Otherwise you can enter any scale you like and it will use that instead.
The only drawback I can find so far is that it doesn't tell you which sheet you're doing the scale for in the inputBox but I'm hoping that might be fixable at a later date.
I hope this helps someone anyway 🙂
Sub Main()
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet  = oDrawDoc.ActiveSheet
Dim oSheets As Sheets
Dim oView As DrawingView
Dim oViews As DrawingViews
Dim oScale As Double
Dim oViewCount As Integer = 0
      Dim drawingDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
      For Each sheetX As Sheet In drawingDoc.Sheets
	        dwgScale = InputBox("Enter Sheet Scale", "SheetX", "ignor")
            Dim titleBlockX As TitleBlock = sheetX.TitleBlock
            If (titleBlockX Is Nothing) Then Continue For
            Dim scaleTextBox As TextBox = GetScaleTextBox(titleBlockX.Definition)
            If (scaleTextBox Is Nothing) Then Continue For
            Dim scaleString As String = String.Empty
            For Each viewX As DrawingView In sheetX.DrawingViews
                  If (Not String.IsNullOrEmpty(viewX.ScaleString)) Then
                  If dwgScale = "ignor" Then
                        scaleString = viewX.ScaleString
						Else
						scaleString = dwgScale
                        Exit For
							End If
                  End If
            Next
            titleBlockX.SetPromptResultText(scaleTextBox, scaleString)
      Next
End Sub
Function GetScaleTextBox(ByVal titleDef As TitleBlockDefinition) As TextBox
     For Each defText As TextBox In titleDef.Sketch.TextBoxes
            If (defText.Text = "<Scale>" Or defText.Text = "Scale") Then
                  Return defText
            End If
      Next
      Return Nothing
End Function
Replies (0)
