Automate Marking Sheet Metal Bend Lines
jwmb224
jwmb224
   our plant has introduced marking bend lines on sheet metal parts for the operators on the press brakes to have an on-the-fly double-check mechanism that they are executing the correct program for the parts they are bending. it has been high successful in reducing all kinds of operator errors, both at the press brakes, and further down the line if the error wasn't detected at the press brakes.
   the issue at hand is, the bend line markers are extremely tedious for the CAD department to install and maintain. (maintain if the part needs changes and inventor can't solve the feature after the changes)
   here is what it looks like after markers are installed:
    the above samples entails creating a flat pattern sketch, including all the bend lines as sketch geometry, adding a hole at each endpoint, constraining all the holes together to speed up entering hole size, cutting said hole, and creating a two corner rounds per each hole to minimize sharp corners for laser cutter/material handling. as you might imagine, this is extremely tedious.
   would it be possible to automate this process using iLogic? i have heard rumors from some of my friends that they've seen it done, but have so far not been able to track down a sample code. i tried submitting the idea to idea station a while back, but it hasn't gotten a lot of traction. i also tried using ChatGPT to write some code for this, but executing the code had 0 effect on the part, and ChatGPT's debug output was empty. i am not a coder, so i don't even know where i would start on this.
   is there anybody that has this running, or could contribute some code to do it? it doesn't sound very complicated. but again, what do i know? all i know is that me and my carpel tunnel would really really appreciate having this.
   in an ideal world, once the part is done, i could execute a certain iLogic rule and inventor would zip through making the markers. i am open to suggests on which feature would do it best between Hole, Cut, Extrude, Punch, etc. If the part changed and Inventor couldn't solve the feature afterwards, maybe it would be simple enough to just delete them all and execute the script again? i think almost anything would be a step up from fully manual.
jared
JelteDeJong
You could try something like this. ( you can change the size of the dimples and their radius in lines 1 and 2)
Dim dimpleRadius = 0.25 'Cm
Dim cornerRoundRadius = 0.1 'Cm
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
If def.HasFlatPattern = False Then
	def.Unfold()
Dim flatPattern = def.FlatPattern
flatPattern.Edit()
Dim newSketch = flatPattern.Sketches.Add(flatPattern.TopFace)
For Each result As FlatBendResult In flatPattern.FlatBendResults
	If result.IsOnBottomFace Then Continue For
	Dim line As SketchLine = newSketch.AddByProjectingEntity(result.Edge)
	line.Construction = True
	Dim c1 = newSketch.SketchCircles.AddByCenterRadius(line.StartSketchPoint, dimpleRadius)
	Dim c2 = newSketch.SketchCircles.AddByCenterRadius(line.EndSketchPoint, dimpleRadius)
	newSketch.DimensionConstraints.AddDiameter(c1, line.StartSketchPoint.Geometry)
	newSketch.DimensionConstraints.AddDiameter(c2, line.EndSketchPoint.Geometry)
Next
Dim profile = newSketch.Profiles.AddForSolid()
Dim cutDef = flatPattern.Features.CutFeatures.CreateCutDefinition(profile)
Dim cutFeature = flatPattern.Features.CutFeatures.Add(cutDef)
Dim cornerRoundFeatures = flatPattern.Features.CornerRoundFeatures
For Each face As Face In cutFeature.Faces
	For Each edge As Edge In face.Edges
		For Each face2 As Face In edge.Faces
			If (face2 Is face) Then Continue For
			If (face2 Is flatPattern.BottomFace) Then Continue For
			Try
				Dim edgeCollection = ThisApplication.TransientObjects.CreateEdgeCollection()
				edgeCollection.Add(edge)
				Dim roundDef = cornerRoundFeatures.CreateCornerRoundDefinition(edgeCollection, cornerRoundRadius)
				Dim tempFeature = cornerRoundFeatures.Add(roundDef)
			Catch ex As Exception
			End Try
		Next
	Next
Next
 There are some situations, that I can think of, where you get unexpected results. For example in this situation if the dimple radius is too big. Then it will also cut the other edge!
Another scenario that could go wrong is when you have cut across bends. In those cases, I have seen that Inventor can give strange results.
Therefore you should check the result of this iLogic rule always manually before you use it in production!
Jelte de Jong
Blog: hjalte.nl - github.com
jwmb224
ha! you did it. works flawlessly on the parts i tested it with. thank you from the united states.
jared
harvey3ELEA
Nice routine JelteDeJong.  I was doing those dimples manually, and while not difficult, they were certainly tedious as mentioned above.  Thanks from Florida!
jwmb224
if anybody encounters this idea and likes it, here is an idea station suggestion i put together of this a while ago, but it hasn't seemed to take off. go vote it up!
harvey3ELEA
Unfortunately, a lot of great ideas go to die over in the Idea Station, but this one's a keeper.
