Autodrawing - iLogic
GKPByDesign
GKPByDesign
Hey I need help with the following.
- Run iLogic on an open Assembly/Part to create a new drawing with every part and subassembly to be placed on a drawing in order of filename
- Create front, side, plan and isometric drawing with a decent scale 1:20/1:10/1:50 etc
- No dimensions required and to just place a drawing
- Place a flat pattern if one is available, skip this step is there isn't a flat pattern (place flat pattern on same page?)
Can this be done at all?
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign ,
Hoping that suggestions in the below blog link may be helpful.
https://clintbrown.co.uk/2018/10/07/automatic-drawings-with-ilogic/
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GKPByDesign
The code copied below from Clint is along the lines of what I want but I want to be able to take it further.
Open assembly,
cycles through every part and sub assembly, auto scales, or manually scale for every page, can this code be adapted to suit?
'Check if this is a drawing file
Dim doc = ThisDoc.Document
If doc.DocumentType = kDrawingDocumentObject Then
GoTo DRAWINGcode :
'In parts & asemblies - Write file name and path to temp text file
oWrite = System.IO.File.CreateText("C:\TEMP\part.txt")
oWrite.WriteLine(ThisDoc.PathAndFileName(True))
oWrite.Close()
oFilePather = ThisDoc.Path & "\"
'In parts & asemblies - Write new drawing name to temp text file
oWrite = System.IO.File.CreateText("C:\TEMP\partno.txt")
oWrite.WriteLine(oFilePather & iProperties.Value("Project", "Part Number") & ".dwg")
oWrite.Close()
'Read Drawing name from text file
oRead = System.IO.File.OpenText("C:\TEMP\partno.txt")
EntireFile1 = oRead.ReadLine()
oRead.Close()
oDrawingName = EntireFile1
'Copy the Template file > keep templates saved in your project workspace, you need a separate part and assembly template
If doc.DocumentType = kAssemblyDocumentObject Then
oCopyFiler = "C:\Users\Clint\Workspace\ASSEMBLY_TEMPLATE.dwg"
Else If doc.DocumentType = kPartDocumentObject Then
oCopyFiler = "C:\Users\Clint\Workspace\PART_TEMPLATE.dwg"
' Check if drawing exists - If it does, opening existing drawing
If System.IO.File.Exists(oDrawingName & DWGType) Then
ThisDoc.Launch(oDrawingName & DWGType)
Return
'Launch New drawing
Dim oNewFiler As String = EntireFile1
System.IO.File.Copy(oCopyFiler,oNewFiler,(True))
ThisDoc.Launch(oNewFiler)
DRAWINGcode :
On Error GoTo Exiter
'Check if we have replaced the reference and scaled the drawing already
oNumbero = Parameter("Opened")
Parameter("Opened") = oNumbero + 1
'MsgBox(Parameter("Opened"))
If Parameter("Opened") > 2 Then
Return
'Read in File name - For reference
oRead = System.IO.File.OpenText("C:\TEMP\part.txt")
EntireFile = oRead.ReadLine()
oRead.Close()
oPartPath = EntireFile
'Replace Drawing Reference
Dim oFileDesc As FileDescriptor
oFileDesc = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFileDesc.ReplaceReference(oPartPath)
doc.Update()
'Read in new name for Drawing
oRead.Close()
'Save this drawing
ThisDoc.Save
'Scale the Drawing - Note your drawing views names("VIEW1")&("VIEW4") must match the template
oMyParameter = ThisDrawing.Document.Parameters.UserParameters
oParameter = oMyParameter.AddByValue("Scaler", "1:5", UnitsTypeEnum.kTextUnits)
MultiValue.SetList("Scaler","1:1", "1:2", "1:4", "1:5", "1:10", "1:20", "1:25", "1:50", "1:100")
Scaler = InputListBox("Set Drawing Scale", MultiValue.List("Scaler"), Scaler, Title := "Scale = " & ActiveSheet.View("VIEW1").ScaleString, ListName := "List")
ActiveSheet.View("VIEW1").ScaleString = Scaler
ActiveSheet.View("VIEW4").ScaleString = Scaler
Parameter.Param("Scaler").Delete
Exiter :
'Msgbox("Scale not Changed")
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign,
Try below iLogic code to get all referenced documents in an Assembly.
Public Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get all of the referenced documents.
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    ' Iterate through the list of documents.
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
        MsgBox( oRefDoc.FullDocumentName )
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
NachoShaw
I have been working on a plugin for a long time, just getting round to picking it up and finishing it. This plugin will
allow you to set positions for assembly, part, presentation files
option part rotation to force landscape parts
adds a flat pattern to a position you visually set (optional rotation)
allows you to choose the view style for each type
gives you a visual designer to help with positioning
set & forget template settings
create sets (in case you have different types of documentation needs)
will create a drawing for each part / assembly / presentation
choice between multi sheet & single sheet
add dims to all views
add view names & optional numbers to each view with a pre-selected style
optional ignore library parts
quick button to run off a full set, active sheet, assembly only, part only
categorized material sets (you can for example print off all sheet metal only)
optional content center fastener sheet
optional add part lists to assembly and / or presentation sheets
should be ready in about a month, just sorting out security on it 🙂
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
