Help with VBA Code and Extracting Properties
I am working on writing code in the VBA Editor, and I am trying to access the properties from a Cross Section Analysis, and show them in a message box. I began by writing some code, and I got the "value" for the kCrossSectionAnalysis. What I want is the area, Ix, and Iy properties (on the right-hand side) of the results from the Cross Section Analysis. How would I access the actual numbers and specific properties from that Cross Section Analysis? I have posted some pictures below showing what I mean.
Thanks.
frederik_vollbrecht
I guess you are new to iLogic /coding.
What you are doing in your MsgBox is just show the ID-Value of the function itself. You can think of it as a Nickname.
What you want to do is get the value of a object. Have a look at this thread:
https://forums.autodesk.com/t5/inventor-customization/cross-section-analysis-and-vba-editor-object-b...
Was the solution helpful? Please mark as accepted or kudo
