Autodesk Inventor Spring/Coil Help
Hi, I made a coil and I want to make the material size thinner how do I do that?
mwighton
Change the diameter of the circle you used for the coil to a smaller value.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
THANK YOU FINALLY GOT IT
