Auto stitch a composite part
I've got around 4000 parts like the attached part. I've been trying to buils a VBA routine to automaticly loop the folder, open each and stitch it.. For some reason i'll get an error of type mismatch
Public Sub AutoStitch1()
      Dim oPartDoc As PartDocument
      Set oPartDoc = ThisApplication.ActiveDocument
      Dim oComp As Inventor.PartComponentDefinition
      Set oComp = oPartDoc.ComponentDefinition
      oComp.Features.KnitFeatures.Add (oComp.Features.Item(1).SurfaceBodies.Item(1))
End Sub
If i just run
      Call oPartDoc.SelectSet.Select(oComp.Features.Item(1).SurfaceBodies.Item(1))
End Sub
And the manuelly run the stitch command and press apply (its already picked), it works...
What do i do wrong here?
Regards Lasse
joris.engelbertink
I'm looking for the same solution. Did you find anything yet?
Greetings, Joris
