Auto resizing dialogue boxes
fridtjofZM5ME
fridtjofZM5ME
Hi everyone, does any of you know if/how you can set Inventor to auto resize dialogue boxes, such as the "Edit Dimension" box in the sketch environment
Most of my parameters are driven by a spread sheet that I've made where I try to give them descriptive names, even if they tend to get long as a result. This sometimes makes the expression in the edit boxes too long to fit in the default size box, so I have to drag it longer to see the whole thing, and then it stays that way until I make it shorter again when the annuisance of the check box being too far to the right gets too overwhelming.
WCrihfield
I know what you mean.  I've wished for, and looked into that before too.  Unfortunately, that's a purely Autodesk behind-the-scenes type stuff.  I've also wanted to be able to specify the size of (or auto resize) the MessageBox, MsgBox, InputBox, InputListBox, InputRadioBox, etc. to a greater extent (as well as a lot more text formatting capabilities within them), to no avail.  I did create a post on Inventor Ideas site for the msgbox stuff, but didn't mention the edit dimension text box.  I also work with a lot of very descriptively named parameters, and attempt to do complex math within those dimension text boxes, which sometimes ends up going across most of my screen.  Then the next 5 dimensions I edit are something like 5, 123, 78.375, 1, etc.
I've never heard of any way to control the size of that specific text entry box.
Wesley Crihfield
(Not an Autodesk Employee)
