Auto number sketched symbols
danmachen
danmachen
I am looking for an iLogic code that will allow users to select multiple sketched symbols and automatically number them and insert as a text box into the drawing.
This is the ideal:
e.g.The predefined sketched symbols are contained in a separate drawing file (which is within the shared sketched symbol library:
"\Inventor Data (MAC)\Design_Data\Symbol Library\General Symbols.idw"
 I found a code snippet here that allows the single insertion of a sketched symbol but not multiple at once and without any automatic numbering.
    Sub Main()
        'Query stamp insertion requirement
        oDrawDoc = ThisDoc.Document
        question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
        If question = vbYes Then
            Dim strSelectedStamp As String = "Result2"
            Dim strStampList As New ArrayList
            strStampRequired = True
            'strStampList.Add("F&C Stamp Round")
            'strStampList.Add("As-Built Stamp Round")
            'strStampList.Add("Test")
            'strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps")
            Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
            Dim SourceFile1 As String = "\\vpfs1\Inventor Data (MAC)\Design_Data\Symbol Library\General Symbols.idw"
            Dim strSourceIDW As DrawingDocument
            strSourceIDW = ThisApplication.Documents.Open(SourceFile1, False)
            Dim symbolDef As SketchedSymbolDefinition
            For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions
                strStampList.Add(symbolDef.Name)
            Next
                If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then
                    CopyFrom = symbolDef.CopyTo(strDrawDoc, True)
                    If MsgBox("Would you like to place the stamp on the drawing?", MsgBoxStyle.YesNo, "Insert Stamp") = MsgBoxResult.Yes Then
                        'Insert stamp if required
                        'InsertSymbol(symbolDef.Name)
            Dim oSketchedSymbolDef As SketchedSymbolDefinition _
            = oDrawDoc.SketchedSymbolDefinitions.Item(strSelectedStamp)
            Dim oSheet As Sheet = oDrawDoc.ActiveSheet
            'create insertion point, coordinates - in cm !
            Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
                Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(10, 10)
                ' Add an instance of the sketched symbol definition to the sheet.
                ' Rotate angle = 0 radians,
                    ' scale = 1 when adding
                ' no prompt text
                Dim oSketchedSymbol As SketchedSymbol _
                = oSheet.SketchedSymbols.Add( _
                oSketchedSymbolDef, _
                oInsertionPoint, _
                0, 1, Nothing)
            Next
            strSourceIDW.Close()
    End Sub
Any help?
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
matt_jlt
Hi Dan, I'm a bit confused on the question. You said you were trying to add multiple sketched symbols onto a drawing but into a text box? Are the sketch symbols just text or are they actual shapes etc.
What is looks like to me is that you have a bunch of sketch symbols that are just text notes stored in a drawing file acting as a library.
You want to run the ilogic rule and have a list of your notes to select from. When you select the items you want it will add them to a text box on the drawing and automatically assign each note a number.
If i am anywhere near the mark and there is only text notes, I would think a simple text file would be much easier to maintain. If it is more than just notes then it won't work as you can't add them to a text box as you stated.
Let me know if you need any help or if I am in the ballpark of what you were thinking.
Matt.
danmachen
Hi there,
Thank you for your response. That's exactly right as you say!
Thats right they are predefined text boxes and only contain text, we just want a method to combine them into one text box by picking multiples of them and automatically number them in order.
Any suggestions welcomed..
Dan Machen
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @danmachen,
Currently, multiple selection is not supported in iLogic. But, a listbox from VBA form will support multiple selection. VBA code is given for a VBA form and Autonumber is also performing.
Here, instead of adding sketched symbol. A general note is used to add text. Before executing following code, a DrawingDocument should be opened.
Private Sub CommandButton1_Click()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oPt As Point2d
    Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
    Dim Msg As String
    Dim i As Integer
    Dim j As Integer
    j = 0
    If ListBox1.ListIndex = -1 Then
        Msg = "Nothing"
    Else
        Msg = ""
        For i = 0 To ListBox1.ListCount - 1
            If ListBox1.Selected(i) Then
              j = j + 1
              Msg = Msg & ListBox1.List(i) & " " & j & vbCrLf
        Next i
    Dim oNote As GeneralNote
    Set oNote = oSheet.DrawingNotes.GeneralNotes.AddFitted(oPt, Msg)
End Sub
Private Sub UserForm_Initialize()
    With ListBox1
        .AddItem " F&C Stamp Round"
        .AddItem "As-Built Stamp Round"
        .AddItem "Test"
    End With
  ListBox1.MultiSelect = fmMultiSelectMulti
End Sub
Following video link explains how to add VBA form in Inventor.
https://www.youtube.com/watch?v=Sr0MvjeEFJU
VBA form can be called in indirectly by iLogic. Initially, a VBA form is called in a VBA module. Then, VBA module can be called by the following iLogic code.
VBA Module:
Public Sub Test1()
    Call UserForm1.Show
End Sub
iLogic code:
InventorVb.RunMacro("ApplicationProject", "Module1", "Test1")
Please feel free to contact if there is any queries.
If solves problem, click on "Accept  as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
