Auto add hole dimension to flatpattern
Darkforce_the_ilogic_guy
Advisor Advisor
I would like to make a code that add dimension to all hole on that flatpattern view. How would i do this using ilogic ?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy,
Hole dimension for Flatpattern in Drawing can be added through below Inventor API link.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-9B263959-A20C-418E-9AF2-CE3795AA8319
For further investigation, can you please provide non confidential drawing to test the same?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I am not sure how to use that. how would i make it ? Ilogic , VBA  or do it need to be  an pungin or extrale program to work.?
And the link you send my are for inventor 2019 and I have 2018. Will it work on my system ? or do i have to wait to I get a update ?
chandra.shekar.g
Autodesk Support
Autodesk Support
Please provide non confidential data to build iLogic code?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
I do not have any code on this at this time.   I try to make a step by step auto of my Drawing system. I have got a Auto Bend note , and I have a small part of the code needed to add Centermarks on Drawing… but at this time I only have wish to make a system that add hole diamension  to an drawing by no code at this time
