Associate File
Associate File
Message 1 of 12
Associate File
I have a two files A.ipt and A.idw. I used the SaveCopyAs method and created B.ipt and B.idw from A.ipt and A.idw respectively. Since B.idw is a copy of A.idw hence it is associated with A.ipt but I want that it should be associated with B.ipt using API. If I am doing it manually and as long as A.ipt is in search path there is no way but if I am removing the A.ipt from the search path and opening the B.idw, Inventor ask the part file of the B.idw and we can associate it with B.ipt. If we make any changes in B.ipt, it gets reflected in B.idw. I want the same result using API. Do any body has idea or some sample code od doing it.
Thanks in advance
Manoj
Replies (11)
Message 2 of 12
Here's some sample code that I believe accomplishes
what you want.  The sample takes advantage of the fact that we know the
particular case.  A more general solution would require a bit more work,
but this does demonstrate one use of the API to do what you want.
Private Sub CreateCopy()
    ' Create an instance of
Apprentice Server.
    Dim oApprentice As
ApprenticeServerComponent
    Set oApprentice = New
    ' Open the drawing
document.
    Dim oDrawDoc As
ApprenticeServerDocument
    Set oDrawDoc =
oApprentice.Open("C:\Temp\FrameTest\A.idw")
    ' Get a reference to the
FileSaveAs object from Apprentice.
    Dim oFileSaveAs As
FileSaveAs
    Set oFileSaveAs =
oApprentice.FileSaveAs
    ' Add the drawing file to the
FileSaveAs, defining the new filename.
    Call
oFileSaveAs.AddFileToSave(oDrawDoc,
"C:\Temp\FrameTest\B.idw")
    ' Add the part file to the
FileSaveAs, defining the new filename.  The part document is
    ' obtained from the
drawing and getting the list of referenced files.  In this case we
know
    ' there's only a single
file referenced so it just gets the first one in the ReferencedFileDescriptors
collection.
    Call
oFileSaveAs.AddFileToSave(oDrawDoc.ReferencedFileDescriptors.Item(1).ReferencedDocument,
"C:\Temp\FrameTest\B.ipt")
    ' Perform the actual SaveCopyAs.  This will
create the copies and readjust the references.
    Call
oFileSaveAs.ExecuteSaveCopyAs
End Sub
-Brian
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Thanks in advance
Manoj
Message 3 of 12
Hi Brian
Thanks for your prompt response. The sample provided by you is what I was looking for. Thanks once again
Message 4 of 12
Brian,
I tried this code but I got "Permission denied". I
suppose it's because my test files was not migrated or?
When I tried to check if the file "
face="Times New Roman" size=3>NeedsMigrating" I got stuck.(Object doesn't
support this action)
Do you
maybe have sample code for this?
Lars
accomplishes what you want.  The sample takes advantage of the fact that
we know the particular case.  A more general solution would require a bit
more work, but this does demonstrate one use of the API to do what you
want.
Apprentice Server.
    Dim oApprentice As
    ' Open the drawing
document.
    Dim oDrawDoc As
    Set oDrawDoc =
    Dim oFileSaveAs As
FileSaveAs
    Set oFileSaveAs =
    Call
the FileSaveAs, defining the new filename.  The part document
is
    ' obtained from the
know
collection.
    Call
    Call
End Sub
-Brian
I
Thanks in advance
Manoj
Message 5 of 12
Brian,
I have tested your sample code and I got
an error (-2147467259 Method 'FileS
aveAs' of
object '_IRxApprenticeServer' failed) on the 'Set oFileSaveAs =
oApprentice.FileSaveAs' part.
(I'm running IV6 SP2/WinXP Pro)
Do you have any suggestion?
Lars
want.
Apprentice Server.
    Dim oApprentice As
    ' Open the drawing
document.
    Dim oDrawDoc As
    Set oDrawDoc =
    Dim oFileSaveAs As
FileSaveAs
    Set oFileSaveAs =
    Call
is
    ' obtained from the
know
collection.
    Call
    Call
End Sub
-Brian
I
Thanks in advance
Manoj
Message 6 of 12
Did you set a reference to Inventor Apprentice before trying to run it?
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Lars Andersson" wrote in message
news:E34B4D61625E96A262BF04351E5DBAF1@in.WebX.maYIadrTaRb...
> Brian,
> I tried this code but I got "Permission denied". I suppose it's because my
> When I tried to check if the file "NeedsMigrating" I got stuck.(Object
doesn't support this action)
> Do you maybe have sample code for this?
Message 7 of 12
Kent,
No I missed that, but it didn't help. Any more ideas?
Lars
"Kent Keller" skrev i meddelandet
news:EECFB1C09841E9FF7E7304F498C652CB@in.WebX.maYIadrTaRb...
> Kent Keller
> > Brian,
my
Message 8 of 12
Lars
Where are you doing this? I don't believe this code is meant to run inside of Inventor.
I started a new file in Excel
Alt F11 to get into the IDE,
RMB insert module
Pasted the code into the module
Changed the names of files in the code to filenames on my system
Added a reference to Inventor Apprentice
And it ran fine.
Kent
Assistant Moderator
news:95C479A74816937A2FE1DB9C5F765731@in.WebX.maYIadrTaRb...
> Kent,
> Lars
Message 9 of 12
Lars,
I don't know what's causing the problems you're seeing, but here are a
couple of things to try. Make sure your files are already migrated. The
second thing is to see is if the files you're using are defined within the
current project. I'm not sure if this would impact this or not, but it's
worth trying.
-Brian
> Kent,
> Lars
> > Kent Keller
> > > Brian,
because
> my
Message 10 of 12
I have tried to create new test files by using IV6 and have a projet set
with Workgroup Serch Path set to the folder containing the files. I have
pasted your(Brian) code as a macro (within Inventor). I have also checked
that a have 'RxApprentice.tlb' as a reference.
Right now is the 'Set oFileSaveAs = oApprentice.FileSaveAs' that cause me
all my problem. (-2147467259 Method 'FileSaveAs' of object
Lars
"Brian Ekins (Autodesk)" skrev i meddelandet
news:523AF7EA6AB635C00AA235FA510D15CC@in.WebX.maYIadrTaRb...
> Lars,
> worth trying.
> -Brian
> > Kent,
> > Lars
it?
> > > Kent Keller
> > > > Brian,
> because
> > my
stuck.(Object
Message 11 of 12
Here is the code. (I have a form with the CommonDialog1)
I'm not a Pro on programming so don't laugh to much........
Sub CreateCopy()
Dim Respons
Dim FileToCopy, FileToCreate As String
On Error GoTo Err_CreateCopy
CreateCopyOfTo.CommonDialog1.FileName = ""
CreateCopyOfTo.CommonDialog1.Filter = "Inventor Drawing (*.idw)|*.idw"
CreateCopyOfTo.CommonDialog1.CancelError = True
CreateCopyOfTo.CommonDialog1.ShowOpen
If Dir(CreateCopyOfTo.CommonDialog1.FileName) = "" Then
MsgBox "File does not exist! File copy terminated."
Exit Sub
Else
FileToCopy = CreateCopyOfTo.CommonDialog1.FileName
End If
CreateCopyOfTo.CommonDialog1.ShowSave
If Dir(CreateCopyOfTo.CommonDialog1.FileName) <> "" Then
Respons = MsgBox("File already exist! Replace the file?", vbOKCancel
+ vbDefaultButton2, "Varning")
If Respons = vbCancel Then Exit Sub
End If
FileToCreate = CreateCopyOfTo.CommonDialog1.FileName
'MsgBox FileToCopy
'MsgBox FileToCreate
' Create an instance of Apprentice Server.
Dim oApprentice As ApprenticeServerComponent
Set oApprentice = New ApprenticeServerComponent
' Open the drawing document.
Dim oDrawDoc As ApprenticeServerDocument
Set oDrawDoc = oApprentice.Open(FileToCopy)
' Get a reference to the FileSaveAs object from Apprentice.
Dim oFileSaveAs As FileSaveAs
' Add the drawing file to the FileSaveAs, defining the new filename.
Call oFileSaveAs.AddFileToSave(oDrawDoc, FileToCreate)
' Add the part file to the FileSaveAs, defining the new filename. The
part document is
' obtained from the drawing and getting the list of referenced files.
In this case we know
' there's only a single file referenced so it just gets the first one in
the ReferencedFileDescriptors collection.
Call
cedDocument, Left(FileToCreate, Len(FileToCreate) - 3) & "ipt")
' Perform the actual SaveCopyAs. This will create the copies and
Call oFileSaveAs.ExecuteSaveCopyAs
Exit Sub
Err_CreateCopy:
If Err.Number <> 32755 Then MsgBox "Error: " & Err.Number & " (" &
Err.Description & ")" 'Cancel
End Sub
> Lars,
> worth trying.
> -Brian
> > Kent,
> > Lars
it?
> > > Kent Keller
> > > > Brian,
> because
> > my
stuck.(Object
Message 12 of 12
I tried "my" code in VB6 and it worked perfectly.
> Lars,
> worth trying.
> -Brian
> > Kent,
> > Lars
it?
> > > Kent Keller
> > > > Brian,
> because
> > my
stuck.(Object
