Assistance required with iLogic rule code for creation of DXF files
Hi everybody,
I am new to the forum and the use of iLogic.
 I have been tasked with the job of creating new model and drawing templates in order to simplify and automate key parts of the drawing process within the company.
I am currently working on an iLogic rule to automate the generation of DXF files if needed an have run into a error which is driving me nuts!  When I run the rule, I get the following message:
"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
Whilst I have some experience of VB, I am somewhat rusty and despite my best attempts to resolve this I have failed miserably.
The code I have written is as follows:
'____________________DXF Generator____________________
'Query user
Question = MessageBox.Show ("Do you require a DXF?" & vbNewLine & "NOTE! This will overwrite any existing DXF files with the same name!", "Export to DXF",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'Set condition dependent on answer
If Question = vbYes Then
 oPath = ThisDoc.Path  oFileName = ThisDoc.FileName(False) 'without extension  oRevNum = iProperties.Value("Project", "Revision Number")
 oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'get DXF Add-in
 oDocument = ThisApplication.ActiveDocument 'declare oDocument as this document  oContext = ThisApplication.TransientObjects.CreateTranslationContext 'declare oContext as TranslationContext
 oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'declare oOptions as NameValueMap object
 oDataMedium = ThisApplication.TransientObjects.CreateDataMedium  oFolder = oPath & "\DXF" 'Sets target folder
 If oDXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then  DXFIniFile = "C:\Vault Workspace\RAMLDXF.ini"  oOptions.Value("Export_Acad_IniFile") = DXFIniFile  End If
'Check for DXF folder and if it does not exist create one
If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder)
'Set the DXF destination file & file name
oDataMedium.FileName = ThisDoc.PathAndFileName(False) oDataMedium.FileName = oFolder & "\" & oFileName & " Rev " & oRevNum & ".dxf"
On Error Goto handleDXFLock
 'Check if the idw has more than 1 sheet  If ThisDoc.Document.Sheets.Count > 1 Then  For sheet_count = 1 To ThisDoc.Document.Sheets.Count
 'If there are no sheets end operation
 If Len(Dir(oPath & oFileName & " Rev " & oRevNum & "_SHEET_" & sheet_count & ".dxf")) <> 0 Then
Kill(oPath & oFileName & " Rev " & oRevNum & "_SHEET_" & sheet_count & ".dxf")
Else If Len(Dir(oPath & oFileName & " Rev " & oRevNum & ".dxf")) <> 0 Then
Kill(oPath & oFileName & " Rev " & oRevNum & ".dxf")
End If  Next sheet_count
End If
'Publish document.
oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
'Error message responses
handleDXFLock:
MessageBox.Show("DXF could not be saved!" & vbNewLine & "The file you are trying to overwrite may be open", "No DXF For you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
MessageBox.Show("IDW and DXF have been saved to current document folder" , "Save IDW & DXF")
End If
Any assistance you guy's can give me will be much appreciated.
Thanks in advance,
Tony
xiaodong_liang
Autodesk Support
Autodesk Support
I tested with your code on a simple drawing. I just changed the ini file path to my folder. The code works well. Does the specific error occur with a specific drawing or step? I re-formated the code and enclosed it again.
'Query user
 MessageBox.Show(oFolder, "Title")
     DXFIniFile = "C:\temp\RAMLDXF.ini"
 End If
End If
            End If
        Next sheet_count
    End If
'Publish document.
handleDXFLock:
Resume Next
End If
