Assign color using Design View Representations at Part Level
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I got help from WEB, but it is not still doing well.
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim ocompdef As ComponentDefinition
ocompdef = odoc.ComponentDefinition
For Each oViewRep In ocompdef.RepresentationsManager.DesignViewRepresentations
	'If oViewRep.Name.Contains("Default") Then		'OK
	If oViewRep.Name = "Default" Then				'OK
	oViewRep.activate
		'DesignViewRepresen​tations.("Default").Activate
		oStockNumber = UCase(iProperties.Value("Project", "Stock Number"))
		If oStockNumber = "BASE PL" Or oBasePL = "BASE PLATE" Then
		iProperties.PartColor = "Orange"
Next
I request help.
adam.nagy
Autodesk Support
Autodesk Support
The only problem I had with the rule was this:
iProperties.PartColor = "Orangre"
I needed to modify it to
Then it worked.
Cheers,
Adam Nagy
Autodesk Platform Services
RoyWickrama_RWEI
Thanks.
