Assign color using Design View Representation at part level
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim ocompdef As ComponentDefinition
ocompdef = odoc.ComponentDefinition
For Each oViewRep In ocompdef.RepresentationsManager.DesignViewRepresentations
	'If oViewRep.Name.Contains("Default") Then		'OK
	If oViewRep.Name = "Default" Then				'OK
	oViewRep.activate
		'DesignViewRepresen​tations.("Default").Activate
		oStockNumber = UCase(iProperties.Value("Project", "Stock Number"))
		If oStockNumber = "BASE PL" Or oBasePL = "BASE PLATE" Then
		iProperties.PartColor = "Orangre"
Next
adam.nagy
Autodesk Support
Autodesk Support
Since you are looking for "Default" design view representation, I assume you are working in an assembly document.
There the parts are represented by component occurrences, so you have to set their colour through that, e.g.:
Component.Color("PartWithHole2016:1") = "Orange"
Cheers,
Adam Nagy
Autodesk Platform Services
adam.nagy
Autodesk Support
Autodesk Support
The same question can be found here:
http://forums.autodesk.com/t5/inventor-customization/assign-color-using-design-view-representations-...
So let's continue there.
Adam Nagy
