Assembly X, Y Z rangebox
NachoShaw
Advisor Advisor
NachoShaw
Hi
in the same way that it is possible to get the X, Y, Y sizes of a part using rangebox, is it possible to get the same for an Assembly? i dont need to draw a box on screen or anything, i just need to return the overall height, width & depth of the assembly into a numerical format.
Any help appreciated
Nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
ekinsb
The ComponentOccurrence object which represents a part or subassembly within an assembly supports the RangeBox property.  This will allow you to get the range box for various components or an entire subassembly.  If you want the range box for the entire assembly you can use the RangeBox property of the AssemblyComponentDefinition object.  The sample code below demonstrates getting the range for the entire assembly.
Public Sub GetAssemblyRange()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim totalRange As Box
    Set totalRange = asmDoc.ComponentDefinition.RangeBox
    Dim xSize As String
    Dim ySize As String
    Dim zSize As String
    xSize = asmDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.X - totalRange.MinPoint.X, kDefaultDisplayLengthUnits)
    ySize = asmDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.Y - totalRange.MinPoint.Y, kDefaultDisplayLengthUnits)
    zSize = asmDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.Z - totalRange.MinPoint.Z, kDefaultDisplayLengthUnits)
    MsgBox ("Assembly size: " & xSize & " x " & ySize & " x " & zSize)
End Sub
 It's important to remember that the range box is always oriented with respect to the world coordinate system and is not guaranteed to tightly fit the model.  This is especially true in an assembly where parts can be repositioned and rotated within the assembly.  What is guaranteed is that the entire assembly will be within the returned range box.
Brian Ekins
Mod the Machine blog
